Question about Canon NP 6650II Copier
Spess Problem My machine makes the spess in every photo copy.
  • 163 Answers
If you have already checked the basics, drum, cleaning unit, etc. There is one unique solution to the 6650 and that is to replace the primary corona unit. No one can explain why but that's what solved the problem.
Posted on Feb 01, 2008
Canon IR 300-405 Problem - E030 this problem has been indicated of per print and per copy. so plz Sir solve this promblem
dear sir i have canon IR300-405 machin.
my problem is error 030 pls full support is my solution
Oct 25, 2010 | Office Equipment & Supplies
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
Probleme code H4
Press # * C * , that will put the machine into diagnostics.
Enter the number 14 as if you were making 14 copies. Then follow the screen directions to clear the fault code. Should be enter 1 then press start.
The machine will reset and should be fine.
Jul 21, 2010 | Sharp AR-5320 Black and White Copier
Sharp 2618
This problem on your copier heater section,I mean bnormal temparature.So you can reset it,.
Press your copier panal board button
C (Clear) Photo(exproser bytton) C Photo
Press 14 Make up and down arrow key press print key(Start key)
C>Photo>C>photo>14>print key
all are ok
Apr 22, 2010 | Sharp AL 1631 Copier
Canon fax-l360 copy darkness
make sure the resolution is on text and not photo when u copy!
Feb 27, 2010 | Canon FAX-L360 Plain Paper Laser
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
Jun 10, 2009 | Canon iR 1600 Laser Photo Printer
I have an error message 1203 how can I fix
Electricial short in ink cartage. Try removing the cartage , clean the contacts on it and on the machine with a pencil eraser, making sure none of the contacts are touching one another.
Jan 01, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Copy machine problem
hello, sir
i have a photo copy machine of canon ir2018N.
my problem is when i start my photo copy machine his inistailzation process start and then given to messeage System ERROR E261 is show.plz sir slove this problem very urgent.thanks
Nov 24, 2008 | Office Equipment & Supplies
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
Canon NP 6650II Copier Logo
52 people viewed this question
old marine
old marine
