HARDISK MY HARDISK IS NOT DETECTING WHAT IS THE SOLUTION PLEASE ADVICE ME
  • Anonymous Dec 19, 2008
    My 80gb I/O Magic Hard Drive won't show up on my new vista laptop. The light is on, and it was working yesterday for some reason. I wanted to transfer files from my old dell desktop to the new laptop using this and now it doesn't work! If you have any solutions that would be great.
    Scholar:
  • 113 Answers
Ok is this on ur startup? (POST) does it say no HDD detected?
if so check the following:
ur HDDis set to master. therefore the little clip on the back and to the right is set over the master pins, this is diff, depending on what HDD it is, look on the top of the HDD it will say... also make sure if u are using ID-0 cables that u have it in the master plug, (the end one) also check to see if the cable is securely connected to the computer on the motherboard (i advise u to use a static grounding device btw)
then boot the computer and enter the BIOS. you click delete when u computer is booting up then check to see that the HDD is set as the main boot device, then cd the floppy.
please ask more if u r stuck.
lamby.
Posted on Jan 31, 2008
Trying to reboot my PC
There is some posibilities that generate that error, this is some of them :
1. Your Hardisk error, your bootable psrtition is corrupt or something, can be caused by not properly shutdown, repair OS with CD recovery may help you.
2. Your hardisk is fine, but you attached new non bootable hardisk, if yes, you may need to change boot order on bios.
3. You attached USB FLASHDISK, or USB Hardisk, try to remove that and rebot your komputer.
Oct 29, 2017 | Computers & Internet
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
My dell gxa is detecting cdrom but does not boot with 98 or xp and after a while it goes to hard disk.....
try to change your booting setup in your bios maybe it reads first the hardisk not your cd rom.
Oct 06, 2009 | Dell OptiPlex GX1 PC Desktop
HP Proliant ML110 Server RAID setting
if you have the RAID 0+1 or 1 ,beacause of the mirroring ,2 disk will be the same.you should be attention ,if you transfer data on the first disk,you must boot your server with that disk.when the system boot completely then you put the second disk ,beacause of the Raid 0+1 or 1 the data of the first disk automatically write on the second disk.
Jun 24, 2009 | HP ProLiant ML110 Server
My hardrive is not picked up in the BIOS
check whether the hard disk is detecting on BIOS or not
Oct 29, 2008 | Lenovo ThinkPad T61 Notebook
Hardisk not detected
Is this the only HD in your system? If so, make sure the jumper on the drive is set to Master. Also make sure you use the Primary IDE controller. Make sure the IDE controller is enabled in the BIOS also.
Oct 16, 2008 | EliteGroup L7VMM2 Motherboard
Cant reformat
check the status of your hard disk on the bios of your laptop is it detecting or not, if its not then you have to replace the hard disk
Oct 03, 2008 | Systemax Neotach 3300 Notebook
Computers & Internet Logo
387 people viewed this question
Alun Cox
David Payne
David Payne
