Hello... This problem is usually associated with a bad switch or a bad window motor. One way to tell which one is listen for the sound of the motor when trying to raise the window. If you hear the motor trying, it is not the problem. Then it could be something is stuck in the window track.
If more help is needed.. Respond to this forum and post a comment.
Good Luck... Mike
Testimonial: "thanks mike but im still not sure what to fix first cause it will go down with no problem just wont go up and there is no noise when i do this"
Hello again... After further research, it looks like your vehicle has relay called the Power Window Relay. This is where I suggest you start the repair.
This item is located either in the fuse panel inside the engine compartment or the one inside the vehicle.
Anymore help need... Post back gain... Good Luck.... Mike
