Question about Xerox Phaser 6110 Laser Printer
Printer says paper jam, but no paper is jammed
Hello Experts!
I have a brand new Xerox Phaser 6110 Laser Printer and have just installed it. Now when I try to print my first page it says there is a paper jam, but apparently there is not.
I am not sure if the paper 100% correctly loaded since the paper slide seems somewhat shacky even after inserting.
What could be wrong?
/Jacob
  • 1 more comment
  • Jacob4700 Jan 31, 2008
    I found the solution by "forcing" the back of the paper tray down so it did not stay in an upward position but was placed 100% horisontal.
    Thanks though Santa.
  • jonja Jun 22, 2008
    Originally had this problem and an engineer fixed it by cleaning the rubber roller. Recently the problem re-occured so i managed to get the rubber roller band off and clean it then put it back on.
    Now getting the Paper Jam response permanently and when i look into the printer when i try to print something, the roller doesn't even attempt to pick up any paper. Doesn't move at all...
    Any advice please???
  • Anonymous Mar 09, 2009
    Paper goes half way out of the paper tray and the red light comes on and then it stops. I open the back panel and close it again and the page comes out with messy toner sploches at the top. repeat, adinfinitum. It did this a while back, then seemed to clear up, now it is back with a vengence.
  • 1,218 Answers
Check the following information.......
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
or
most of the time for a paper jam, there is a QUEUE of papers waiting to be printed. id take out the usb cable via the back of the computer {the one that connects to the printer} go into the control panel, look for printers, double click on that, find the printer, it should say {working offline} right click that, choose the uninstall/delete opts. turn off the printer. reboot the machine, wait until it boots all the way up. take the printer, turn it on, then plug back in the usb cable to the back of the machine. if it is windows either xp/vista it will auto find the usb cable and install automatically. you can then go back to the control panel, printers and it should be listed in the directory. try to right click go to properties of the printer and do a TEST PRINT, should print out.
Posted on Sep 16, 2010
Sometimes if that happens it means that the rollers could not pick up the paper. Try lightly rubbing a bar of soap on the rollers. Just don't overdue it.
Good Luck,
SANTA
Posted on Jan 31, 2008
I spent 2 hours getting one to print its second page, culminating in putting 2 pieces of fine wire under the paper pick roller rubber to make it work...
Posted on Sep 03, 2008
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
The printer keeps saying there is a paper jam at tray 1 but there is no jam
It is not picking up the paper. You need to either clean or replace the feed roller on tray 1
Jan 16, 2011 | Xerox Phaser 6110 Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
I get a paper jam every time I use my Xerox 6110 MFP Printer. It jams on every document while printing or copying.
same problem here expert at Xerox adviced to clean black rollers on the papertray
maybe it works for you, not for me though ;-(
Aug 11, 2010 | Xerox Phaser 6110 Laser Printer
Have a HP Laserjet 2840..error reads "paper jam tray 1" there is no paper jam I can find. Help !!!
There are paper sensing switches above the paper tray. Most likely the actuator has fallen out .
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
Red in xerox 6110
check the waste toner (it's on the left side of drum unit when you open the front cover) cartridge or paper jam if blinking!
Dec 04, 2009 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
May 06, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser  6110 Laser Printer Logo
8,100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
