Question about Microsoft Windows Server Standard 2003 for PC
Windows2003 server networking problem
I have fresh installed windows2003 server on mercurry via chipset motherboard,on board sis lan.when i ping to other pc in lan it gives request timed out.please give me solutions
thanks in advance
pramo ingole
I am Anant.
Mumbai,India.
Here's what you can try to fix your problem...
Be 100% sure that you have successfully installed Windows 2003 without getting any error message during setup.And you didnt ignore any warning message during setup. Ensure that said hardware is in the Hardware Compatibitility List (HCL) declared by Microsoft. As you have done a fresh installation of the Server 2003 I would suggest you to see the status of the device driver in the Device Manager. See that appropriate drivers are installed. Also check if there is any update to those drivers. Get it from the vendor & apply it. After drivers are properly installed you self ping the NIC by using
Ping localhost
OR
Ping 127.0.0.1
Its a local NIC's address. If you get reply to this ping request you have correctly installed your Network Card.
Then the next step would be to check the IP address for the NIC using which your NIC will communicate with other nodes in the network. See if its assigned automaticaly by DHCP in your environment. Or you have to configure it manually. If so properly configure IP , subnet mask & gateway if required.
Now check the connectivity to the network.
If you have already done these checks what I would suggest you to check IRQ of your NIC for any conflits.
As you are might be aware of the Windows Firewall introduced by Windows Server 2003, which is capable of blocking ICMP requests.i.e. Request for ping commands. Try disabling it. Or check with your network Administrator for the port you have connected your Server machine on. Check it with a different pc that it works properly.
If it still frustrates you try another NIC on your motherboard.
These are few things you could check for on your computer.
Reply me if it works for you or any other solution the fixed the issue.
Thanks.
Anant.
Bye.
Posted on Feb 06, 2008
  • 449 Answers
If the pc mother board came with a driver, install network driver/speed.make sure your network card are working very well and you can fastening the speed of the modem before querying it
Posted on Jan 31, 2008
6ya staff
SOURCE:
How to install lan driver on dh61ww board for windows server 2008
Buy a new network adapter(D-Link DFE 520TX). connect it via the PCI slot. It will be automatically detected by the system.
Jan 30, 2013 | Intel Desktop Board DH61WW Classic Series...
Dh61ww mother board lan drivers for 2003 server
Hello here is the drivers site:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+6+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DH61WW
But here is no drivers for windows 2003.
The 2003 is based on windows xp so you can try the xp driver.
Or you can buy a network card to add in the pci slot.
Just make sure the driver is available for the system.
Good luck
Dec 18, 2012 | Intel Motherboard
How we check what lan driver install
first you must tell which os you have installed xp/vista/7
because the steps are different
Apr 10, 2010 | Intel Asus P5SD2-X SiS 656 SiS 965L...
We reformat our computer but we lost our cd for motherboard, how can we get a new installer for mother board pm2mp
u can solve it by seeing at least you must know the chipset that added in that mainboard,,,is that via p4m266a??its easily find the driver..please follow this link : http://www.biostar-usa.com/upload/Driver/Chipset/VIA/VGA/S3DDR/Win2KXP.exe ( vga ),http://www.biostar-usa.com/upload/Driver/Chipset/VIA/Chipset/VIA_HyperionPro_V521A.zip ( chipset ),http://www.biostar-usa.com/upload/Driver//Audio/VIA/AC97/VT8235.exe ( sound ),http://www.biostar-usa.com/upload/Driver//LAN/VIA/LAN.zip ( LAN ),try it..have a nice day
Oct 19, 2009 | Mach Speed PM2MP Motherboard
Km266-mnb Mother Board .... pc2100 ddr266 ram, will high density ram be compatible? Thanks
By this do you mean you want to increase the RAM on your computer?
I suggest you use PC2100 DDR RAM (same speed) and increase the total RAM to what your require but use the same RAM manufacturer if possible.
If you want to install more than 2Gb of RAM, check the motherboard specification for the maximum RAM that the motherboard can support.
Your motherboards may support more RAM with a BIOS upgrade.
Sep 06, 2009 | Azza Computers & Internet
ASUS P5KPL-AM VIA HD Audio Device not found
I would try the realtek audio driver instead. there are two different audio drivers for that board. Here is the link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
select the socket 775 then look for the p5kpl board then look in the audio section and select the realtek driver
Jul 15, 2009 | Computers & Internet
My computer restarts before installation completes
GO INTO SAFE MODE REMOVE ALL OLD DRIVERS AND ANYSOFTWARE THAT MAYU CONFLICKS AND RESTART SYSTEM
SAFE MODE MAY ALLOW INSTALLATION OF NEW DRIVERS IF SO DO IT IT WILL HELP YOU ALOT.
IF NOR GOINTO CONTROLL PANEL SELECT NEW SOFTWARE LOAD NEW DRIVERS
CANDYMANGANDY
Jan 27, 2009 | Abit AX8 NVIDIA VIA K8T890 + 8237 Chipset...
Matsonic ms9158ep sound drivers
plz mother board matsonic ms9158ep sound driver free down load
Dec 19, 2007 | Matsonic MS9158EP (DSMTSMS9158EP)...
Microsoft Windows Server Standard 2003 for PC Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
