Question about Epson LX-300 Matrix Printer
LX 300 problem
How can i fix the over lapping of charcters and spaces in my prints in LX300
  • pangaz Mar 07, 2008
    printer allignment
  • 749 Answers
If your printer is more than a year old... it's time to clean the path of the printer head and PUT OIL OR GREASE in the rotating gears and the IRON ROUND BAR WHICH HOLDS THE HEAD... drop an oil on it, to make it slippery and makes the head movement smooth.
If it doesn't work... Better have someone fix the problem of the head, it's sensitive and most delicate part of the printer.
This will work, I'm sure of it...
Posted on Jan 31, 2008
    Problem Solver:
  • 9 Answers
Pls. re-alignment of printer if its work its fine other not then pls change the head caridge or bush of head caridge
regards
parvinder
pls. rate my profile if ur problem solve
thanks
My epson LX-300 printer got wrong. it's printed strange character seem wingdings character. i used continous form, LX300 pulled the paper over n over. pls tell me how solve it tks
either corrupt drivers, or bad print head. Try reinstalling the drivers for the printer. Otherwise, the problem will be more expensive to fix then to replace the printer.
Apr 30, 2009 | Epson LX-300+ II Matrix Printer
Epson LX300 page print problem
the page length is not properly set.
Refer your user manual and set the proper page length.
Feb 10, 2009 | Epson LX-300 Matrix Printer
Prints on the sides only and not in the middle
it print on the sides only even though the paper is fitted well give solution to solve this problem
Dec 19, 2008 | Epson LX-300 Matrix Printer
SETUP FOR LX300+ IN REDHAT 9
change the port setting at bios . change lpt port setting in bios ,
Aug 16, 2008 | Epson LX-300 Matrix Printer
Printing shows doubling
alguien por favor envieme los drivers de la impresora EPSON LX300 les agradesco
May 26, 2008 | Epson LX-300 Matrix Printer
Print output
I had the same problem when printing on Windows XP Pro or Vista Business OS while the prinout was fine using DOS or Linux environment. My problem was that every other line the fonts wiggle sidewards towards the right as if it were on italics.
To correct this, simply download the LX300-II ESC/P driver then update your printer driver by re-installing it using your device manager.
Apr 16, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
May 26, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
412 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
