Question about Planar PL2010M 20" Flat Panel LCD Monitor
Backlight replacement How do I get my backlight replaced on my 2010m Planar monitor? Should I attempt this myself? Where can I just buy the backlight? Any assistance would be appreciated.
    Problem Solver:
  • 13 Answers
Are you sure it's the backlight? Many Planar LCD monitors have issues with the capacitors on their power supply boards. The symptoms include a power light and no picture, or just a flash of a picture when powering up and then nothing.
The fix for some of these problems is about $8 on new capacitors (Plus shipping).
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3/4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work if the failure looks like I described. I've fixed several of these monitors so far. All the problems were related to the power supplies. Same with the Planar PL1700 LCD monitors.
Posted on Dec 06, 2008
    Scholar:
  • 24 Answers
LCD backlights are custom designed for the specific panel. If they make it available at all, you would have to contact Planar, or perhaps the manufacturer of the glass themselves for suggestions. This is not typically something most people can do themselves (it's a kind of "if you have to ask, you're going to have problems" thing), and it's not as if these are typical off-the-shelf items, at least not CCFL lights for large panels.
Are you sure it's not still under warrenty? Most manufacturers rate their backlights at 50,000 hours MTBF... that's decades of normal use. As such, they cover them pretty well. This monitor was released in 2004, and Planar includes a 3-year warrenty with 2-day replacement or some-such... check them out here:
http://www.planar.com/products/flatpanel_monitors/pl_flatpanel/PL2010M.cfm
Posted on Feb 01, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
Planar Pe191m goes dark image seen with flashlight
I would suspect either the power suuply or inverter circuits, look for bad caps first which is common problem, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
If you want replacement lamp, you can look here, it also gives you info on how to measure the lamps dimensions: http://www.lcdparts.net/
Mar 08, 2010 | Computers & Internet
I have a PE171 Planar monitor. goes black when turned on
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
Feb 24, 2010 | Planar PE171 (Black) 17 in. Flat Panel LCD...
Screen goes black after a few seconds
Problems like these happen all the time with LCD monitors. Usually one of two things. Bad Capacitors or a bad backlight. To check this, take a flashlight and point at your monitor (usually at a high angle) and see if you can still see the desktop faintly. If so then its either the back light or capacitor. Backlights shouldnt need replaced too often as they have a extremely long lifespan. Capacitors are relatively cheap and easy to replace, all is required is a soldering iron and an inexpensive trip to a Radio Shack. Though this isnt your monitor, it is a very good tutorial on how to go about replacing the capacitors.http://www.wizardanswers.com/liquidvideorepair.html If it is the backlight, here is another tutorial for that :D http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
Jun 12, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
Label over the functions needs to be replaced
theresa_bugb, If your monitor is not in current production by the manufacturer your chances are slim to none of obtaining a replacement. Have you searched out the manufacturer over the web? Try going to a local electronics retailer and check with their service department and find out if they even service this PLANAR monitor or can even order replacement parts. All I can tell you is good luck, doll. I'm louie12fix on fixya or lmistyrel @ aim.com
May 05, 2009 | Planar VS17.4SXAD-DSK-US 17.4 in. Flat...
Planar 2010M auto adjust
This may be related to a power supply problem that these monitor have. I think you need to fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they have weird / intermittant problems.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company before you buy from them. I've seen a lot of complaints for this "international" company.
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors. (about $8 in new capacitors, plus shipping)
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technician for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
There is also a single capacitor on the display logic board, but I haven't seen this one go bad yet.
-Chip
Nov 22, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor will not stay on.
It could likely be the flyback transformer, usually found in the right or left rear corner of the monitor. Be careful though, it packs enough stored power to kill ya. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Planar XP17W (White) Monitor
Planar PL2010M 20" Flat Panel LCD Monitor Logo
826 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
Tom Chichester
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
