Question about Samsung Digimax A400 Digital Camera
RE: POWER ON PROBLEM
Hi!
when I press power on button on my camera it brings 3 beeps and then turn off it self within seconds
  • 3 more comments
  • dedyleclerc Feb 04, 2008
    I have the same problem, it's a 1 year camera, not use at all.
    I press open, I can see few second samsung in color and after that all it's blac.
    The batteries was full and new. Objectif dont open.
  • chyll85 Nov 03, 2008
    yes my camera does the beeping thin and turns off as well with full batteries
  • Anonymous Nov 26, 2008
    I have the same problem with new batteries.
  • Mu5hy Mar 17, 2009
    Same with mine.
    I have a samsung digimax a4 & whenever I press the on button I hear 3 beeps & then it goes off.Also the lens barrel is stuck out of it's cage.
  • alasion Apr 03, 2009
    same problem how do you solve it.i contacted samsung they told me to change the batteries for highpowered ones.made no difference
When I press power on button on my camera it brings 3 beeps and then turn off it self within seconds
Posted on Feb 25, 2009
J'ai trouvé la solution
le probleme que vous avez :
quand vous allumer l 'appareil photo il bip 3 fois et marque pile faible tres rapidement alors que les piles sont neuves et le zoom est resté ouvert.
solution:demonter l'appariel (5vis),prenez 3 piles neuves mettez les sur une table en les joignant - + - + - +,prennez 2 fils electriques ,mettez 1 fil sur le - de la premiere pile a droite et 1 autre fil sur le + de derniere pile a gauche apres faites toucher les 2 fils au borne du moteur du zoom et il rentrera
je pense que ce probleme est du a un manque de puissance avec 2 piles pour faire rentrer l'objectif céest pourquoi j'ai utilisé 3 pile pour le faire rentrer
Posted on Nov 28, 2009
  • 104 Answers
U check battery,otherwise this is mechanical lense barrel stuckup
Posted on Feb 01, 2008
    Sniper:
  • 88 Answers
Mine does this unless i have it in standby when I power on
Posted on Aug 19, 2009
Kssc42qms01 side-by-side. About a month ago refridgerator side was too warm. Removed top grill and cleaned coils. All was fine until today. High temp warning (beep) and both compartments now reading...
I just checked my sheets on this unit, this unit has to be turn off first, turn it back on and can only enter the service mode within 13 second after power up. Hold the filter rest then power button for three second. I hope this helps. Good Luck
Oct 01, 2013 | KitchenAid Refrigerators
Tip
Playstation 3 no display?
Have you changed from A/V to HDMI and now cannot get a display?<br /> <br /> Playstation 3 not showing video but playing sounds?<br /> <br /> Follow these very simple steps to bring your Playstation 3 back to life!<br /> <br /> <u>Step 1.</u><br /> <br /> Turn the Playstation 3 off into standby mode (red light on)<br /> <br /> <u>Step 2.</u><br /> <br /> Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep<br /> <br /> <u>Step 3.</u><br /> <br /> Wait for the Playstation 3 display to initialize.<br /> <br /> Your Playstation 3 should now display properly and you can get back to your gaming!<br /> <br /> Hope this tip helps you out.
on Nov 10, 2010 | Sony Playstation 3 (PS3) Console
I used an hd cable with my ps3 on a different tv now it wont work with my original lead to the original tv
Step 1.
Step 2.
Step 3.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Nov 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Corrupt hardhrive msg comes up and can not do anything
Follow these steps to try and bring your hard drive back to life :-
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off please let go of the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps let go of the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
No screen comeing on tv does turn on all lights come on
Please try the following steps :
Step 1. Turn off the PS3 into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear the second beep.
Step 3. Wait for the PS3 to start up
What this does is reset your video output back to standard definition and you should be able to set up your video properly from within the settings menu.
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Samsung Digimax A400 Digital Camera Logo
425 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
