Question about Fisher and Paykel OS302SS, Stainless Steel Single Oven
How do I set the clock?
Have a Zest series, and can't figure out how to set the clock. Only two buttons for the timer.
  • 25 Answers
According to owners manuel push clock button and turn setting knob. go to this web sight to download or read the manuel
http://www.fisherpaykel.com/cooking/index.cfm?productUid=9A835408-BFF9-38F9-29262A3460B03423&section=supp
Posted on Feb 01, 2008
How do I set the clock/timer to make the oven work?
does it have a clock button , if so press it then use the +or- buttons to set the time then press clock again
Dec 06, 2015 | Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Oven fan does not turn off when oven turned off.
  • The fan runs on for a while after the oven is switched off to cool the oven compartment. It does go off eventually. This is the case for al fan ovens. I hope this helps
Apr 07, 2014 | Fisher Ovens
I have a Bosch built in oven and don't know how to set the time on it
turn the oven off at mains for a few secs. When you turn it on the display should flash 0.00 or 12.00. Press the clock button once ( don't hold it in) use the + or - to set time. Once time selected don't press anything else after a few secs the oven will register and hold you selection.
Apr 03, 2013 | Bosch "27"" Single Wall Oven 500 Series -...
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Can not re set time
Are you trying to reset the timer or the Clock? It's a bit different on each stove, but usually if it's the clock, you press the Clock button TWICE, the time will then begin to flash on and off. then press the + or - sign to increase or decrease the time. When you have gotten to the time you desire, PRESS the Clock button ONCE more. The time will be set, & then you should be all set :).
If it's the KITCHEN TIMER, Press the Kitchen Timer button ONCE, the timer will start flashing. It will usually flash all 0000's. Press the + sign to add minutes, then Press the Timer Button ONCE again, it will be set to the amount of time you added and will beep once the time runs out.
Disclaimer: This instruction is primarily for the General Electric Stove. If you state your specific model, I could be more specific.
Nov 12, 2010 | Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
I have an old whilpool kitchen range and I moved and the timer buttons got turned. How to set the timer buttons to get the stove burners and oven to work, lost the manual.
if you have a clock where the hands go around and smaller start and stop clocks, here's what to do. set the clock to current time, push in the stop button and turn it until it stays in, then push in the start button and turn it until it pops out. try this.
Oct 15, 2009 | Whirlpool Ovens
Cannot set clock Model RBS245PDB2
you need to replace the clock timer board..
Aug 09, 2007 | Whirlpool RBS245PDS Electric Single Oven
Fisher and Paykel OS302SS, Stainless Steel Single Oven Logo
1,435 people viewed this question
Top Fisher Ovens Experts
Dennis Boxerman
Richard
Richard
ray gallant
Are you a Fisher Oven Expert? Answer questions, earn points and help others
