Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Problem when i turn my tv on it just turns right back off i know its an older tv but can u help
  • Pioneer Master
  • 5,138 Answers
Thier is a number of reasons to why your set will not come on and stay on its possiable that you have a leaky capacitor in the high voltage circuit.If you really like this set call a repair shop it will need to go in for repair. thank you & have a nice day.
Posted on Jan 31, 2008
My TV turns off right when I turn it on do you have anything you can tell me that will help?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 11, 2017 | Televison & Video
Samsung lcd Backlight Failure
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 26, 2014 | Samsung LN40B630 40 in. LCD TV
Samsung tv wont turn on and lights stay flashing in front
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 04, 2013 | Samsung Televison & Video
I turn it on with a remote and it turns right back off.
This is a older rear projection set. What I have seen and suspect is your problem is this set develops bad solder connections with age---this is a normal thing as the boards expand and contract when hot and then cool down.
Most likely some connection in the power supply has broken loose---I fixed several where it was a 20 minute job to get at the bottom of the circuit boards and resolder poor connections.
Let me know if you have questions as I am here to help.
SD TECH
Aug 10, 2010 | Mitsubishi VS-4543 45" TV
I lost the manual and i dont know how to program it please help its an older direct tv remote?
10 Steps to Program Your Directv Remote
1. Turn on television.
2. Locate the switch at the top of your remote that allows you to toggle between receiver, auxilary, and TV modes. Slide switch over to"TV".
3. Hold down MUTE and SELECT until a small green light at the top of the switch blinks twice.
4. Enter code 9911.
5. Press and release the CHANNEL UP button repeatedly until television turns off.
6. When TV turns off, press SELECT.
7. Next, press the power button. This should turn the TV back on.
8. With television on, press and hold down MUTE and SELECT again until the small light blinks twice (same as in step 3).
9. Entercode 960.
10. Slide switch back over to "DTV". Your remote is now ready to use!
Jul 01, 2010 | Philips DIRECTV R15
Unable to manually turn on tv... want to use universal remote.
Purchase a universal remote control and follow the directions for using it.
Jun 13, 2017 | Sharp 32L-X2000 32" TV
I need a code for an older zenith tv 13"
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Aug 01, 2008 | DISH Network IR Remote Control
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
26 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
