The first step is an inspection. If it develops no pressure at all in the tank you probably have a mechanical failure of the pump. But before tearing into that, listen as the unit runs, does it sound different from usual? Any hissing of escaping air? Check the intake air filter for blockage. If the unit was used for spray painting, perhaps the air is choked off by dried paint. If you have not found it at this point, it must be a problem with the pump. Any chance of warranty? (you might want to ask sears)
Testimonial: "yeah it still under warranty Ill try that first. Thanks "
