Question about O2 Xda IIs Pocket PC
Automatic Hard Reset
Recently my PDA in few occasion just hard reset on itself without me pressing any keys or run any software:
a.) When I click on turn off WIFI, suddently the screen blank and a hard reset being performed.
b.) I select soft reset icon in SPD software, and it turn out to be a hard reset.
c.) When I key in contact list, seuddenly blank screen and hard reset being performed.
Is it a hardware problem or software? I have use this unit for almost 2 years and I never encounter such problem until recently.
Please advice. Thank you
  • Anonymous May 11, 2010
    please let me know that did you install any application on your PDA
  • 146 Answers
A loose battery can bring such problems. make sure battery is properly tight fit in its cabin. polish the contact points if they are not clean.
good luck
Posted on Feb 01, 2008
6ya staff
SOURCE:
How to remove Windows 7 password to let Toshiba laptop boot from hard drive successfully?
Windows operational system locked always leads to Windows 7 not boot from hard drive completely. Actually, that just need you type correct password to login Windows 7. However on this occasion, only password reset disk or password recovery could help us remove locked Toshiba Windows 7 password.
1. Remove Windows 7 password with reset disk
When you type incorrect password, the window will prompts you that Reset password. Click the link to begin password reset with disk.
Following the password reset wizard, you can easily reset Windows 7 password with boot disk.
2. Remove Windows 7 password with password recovery software
Step 1: Download Windows 7 Password Genius from Internet.
Step 2: Install and run it on accessible computer.
Step 3: Take blank USB disk and insert it into accessible computer for password reset disk burning.
Click "Begin burning" to create a Windows 7 password reset disk. Exit USB disk from the computer when you see the message "Successfully burning".
Step 4: Plug USB reset disk into locked Windows 7 computer, set it boot from USB device.
Step 5: When Windows 7 Password Genius program runs in WinPE, choose accounts and click "Reset password" to remove these accounts password to be blank.
Reboot locked computer and it will boot from hard drive successfully, without any login password anymore.
Aug 21, 2013 | Computers & Internet
My blackberry doesnt have signal? wat can i do?
Hi, The wireless transceiver must be re-initialized and the BlackBerry Device Software must be reloaded.
To resolve this issue, follow these stepsfrom A to C:
A) Perform a hard reset on the BlackBerry device
1) Remove the battery cover from the back of the BlackBerry smartphone
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
B) Re-initialize the manual scan
1) Go to Options
2) Mobile Networks
3) If Netwrok Selection Mode is Automatic then
4) Using scrol ball select the Automatic press Enter or pree Menu key
5) If you press Menu key select Change option or
6) If you press Enter then select Manual
In any case it will starts scanning the Network And then you will see list of service providers,
Please select the one which you are using, like Aircel, Vodaphone etc
7) Then click Ok and then come to Home screen and please do Hard Reset as steps are mentioned above.
C) Run the Application Loader tool from BlackBerry Desktop Manager to reload the BlackBerry Device Software.
I hope this information will be helpful to you
Nov 27, 2009 | RIM BlackBerry Pearl 8100
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
Axim x30 won't come up
The Dell Axim X30 be soft reset by pressing the "Reset" button (from the stylus tip) on the rear of the unit, below the battery.
If the Dell logo in blue background lights up and then goes off again, its probably the brightness setting of your unit. Once the device has started up, just press and hold the jog wheel (the volume wheel above the headphone jack on the left side of the PDA) and press the UP directional key in the front bottom of the PDA. Every press of the up key should brighten up the screen a bit.
If the above solution does not work, you probably might need to hard reset your device.
WARNING: A "hard" reset wipes the RAM and returns the Pocket PC to its factory defaults. You might (mostly) lose all your data if you perform a hard reset. Do not hard-reset your device without having a backup of your data.
The procedures for hard resetting your ppc is given in a very detailed steps in the following page:
http://www.pocketpccentral.net/help/dellx3reset.htm
Apr 24, 2009 | Dell Axim X30 Pocket PC
Slow respond
The best solution to these problems is hard resetting your device. A hard reset will bring your PDA to it's factory default state, so your PDA will be as fast as it was when it was brand new. But this process will erase all your stored data (Such as adress book, messaged, appointments, tasks, pictures, ...) so you should consider having a backup of your PDA to your PC with a backup software before you hard reset your device. So later when you hard reset, you can recover the personal data with this backup file and continue using your PDA faster.
To hard reset your PDA, you must press the on/off button and reset button at the same time (reset button is a small button that needs to be pressed with your pen, and usually it is located in the bottom of the PDA). And later, wait a couple of minutes and the windows will be reinstalled and load up with the starting page of the screen alignment. After you completed all the settings, you can recover your data from your backup file (from PC).
Apr 03, 2009 | O2 Xda IIs Pocket PC
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
I was trying to move an address list from the computer to my hand held and suddenly it has Please Wait on the screen of the hand held and it will not turn off or do anything
try to hard reset
It is some time very important to Hard reset a PDA for example if you want your PDA to be factory default or or operating system corruption etc the following are the information, how to do a hard reset on every PDA as different PDA manufacturer have different methods.
To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-5 seconds. Release both buttons and you will see a confirmation screen asking you if you would like
Dec 31, 2008 | Computers & Internet
Will not shut off
I recalled a problem a few years ago with my PDA and the solution (from Palm while still under warranty) was to do a HARD RESET of the unit.
Please note that a hard reset will wipe clean all memos and other information stored in your PDA. Make sure you HOTSYC your PDA before doing a hard reset. It will reset the unit back to its original factory setting. The way to accomplish this is by holding down the on/off switch while pressing the reset button on the back of your PDA. It will respond back by asking if you really want to reset (yes or no).
I did this and now I can turn off my PDA without worrying about it coming back on. Now all I have to do is figure out what in the old config (that's now backed up on the desktop backup) is freaking out the PDA and causing it to not turn off. Chances are it's a software that was recently added.
Hope this helps!
Good Luck and Happy New Year!
Dec 03, 2008 | Palm Tungsten E Handheld
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
To perform a soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
To perform a hard reset
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
O2 Xda IIs Pocket PC Logo
129 people viewed this question
Top O2 Computers & Internet Experts
Ekse
xxxxxx xxx
Mufaddal  Kurlawala
Mufaddal Kurlawala
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
