Question about Mitsubishi VS-50605 50" Rear Projection Television
Suddenly convergence problem
I just inherited the VS-50805 TV. It had been working fine. Suddenly the convergence problem occurred. I still saw 3 RGB colors; however, they were not lay over each other to make white color. I tried to reset it to manufacture default, yet it did not work. Please help
  • sdnn Feb 01, 2008
    I opened the back of the TV set today. Before I tried to locate the IC, I turned on the TV, I can only see the Blue CRT brightly, the Green and Red didn't seem to light up at all. Is it still conversion IC problem?
    Thanks for your help
  • sdnn Feb 05, 2008
    Hi ctf1800,
    I went ahead and changed the ICs. Lamps seemed to be brighter and fonts sharper; however, I still have convergence problem. Please take a look at attached image. Besides, if i plug in, say DVD movie, I didn't see any pictures at all, the screen just all black.
    Really appreciate for your help.
    Regards,
    sdnn
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 31, 2008
  • Cary Farah
    Cary Farah Feb 01, 2008
    tap on the board and the crt board see if they come back. could have a loose connection.
  • Cary Farah
    Cary Farah Feb 06, 2008
    check the resisters and your soldering 1Watt axial lead fusible resistors: 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms.
Is it a difficult to replace the convergence amplifier modules on a Mitsubishi VS 50609 TV?
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
I have audio but picture blacks out
You may have a bad ground on your vertical IC to begin with! Other repairs would include a bad ground on a coil or the horizontal transformer. The biggest problem is, Yes you have some bad grounds. Repair will be, to find the cracked rings underneath the boards and resolder. Take this note to your local TV Tech, this is your best defense in keeping the the repair cost down! Knowledge, in this case, is on your side now. Good Luck in your search!
Jul 03, 2010 | Mitsubishi VS-50805 50" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
Colors out of alignment
If you have background in electronics, you can do it. The difficult part here is on how to access those convergence amp(convergence circuit output IC). By replacing those 2 IC and some resistors sometimes, adjust the convergence and your done. Good Luck
Mar 05, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I have a mitsubishi model vs-50805 projection tv and my picture has a 3d effect u can see the letters in the menu in 3 colors
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Jan 25, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
