Question about Sony Cyber-Shot DSC-P52 Digital Camera
Sony DSC-P52 Lens Cover Problem
I need to replace the tiny gear that opens and closes the lens shade. Does anyone know where I can find these gears?
  • 6 more comments
  • eglideic Jan 31, 2008
    Well they will sell me the entire machanism for $40.. I can get another whole camera on Ebay for that. I only want the individual gears or perhaps a good used lens cover closure mechanism.
  • Anonymous Feb 01, 2008
    how do i get the lens apart?
    lens cover will not open fully and camera has message, error turn off and on power.
  • amitab23 May 04, 2008
    I am facing the same problem. I get the message on the screen and lens shutter does not close
  • Anonymous May 20, 2008
    turn the power off and on again---------------this the message i'm getting
    and the cover of the lens does not fully open
  • Anonymous May 28, 2008
    You can now find these gears in eBay stores for around $12-$13 shipped.
  • nicole839 Aug 21, 2008
    The Lens does not open completely when you put it on the camera selection and it says to "turn the camera on and off again".
  • Anonymous Sep 09, 2008
    Lens cover grinds and a message appeared on screen to turn camera on and off, which doesen't help.
Is there a setting for the lens gear on the DSC-P52?
Posted on Jun 26, 2008
  • 23 Answers
Check with sony parts and accessories deptment 1800-488-7669
Posted on Jan 31, 2008
Sony Cyber-Shot DSC-S500 Digital Camera Lens Broken
The timing gears are way of sync, the gears have to be re-timed in order to resolve the issue, a camera shop would be able to give a better idea of cost.
Apr 15, 2012 | Sony Cyber-Shot DSC-S500 Digital Camera
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cybershot DSC-P52: Lens Cover Failure
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it's something simple, a power-down reset may help. Turn the camera off, remove the battery, let the camera set for at least 30 minutes, then replace the battery and power up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 18, 2009 | Cameras
Can I make photos without the lens open. As a normal camera in the sun.
no itz not possible in any proper camera...with the lens closed nothin wil get clicked....itz necessary to open the lens
Oct 28, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
When using camera, the lens will not come completely open or clos
You have broken last (black) gear in opening/closing mechanism. Common problem. Need new gear or fix missing "tooth".
Sep 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Turn the power off and on again
Is it model with automatic cover of lens, like the DSC-T3 has? Problem is probably with lens cover. Try to move it (or help while it is trying to open/close) by your finger. It does sometimes if it is dirty (inside). I gues because you did not write the model name and number and on the picture is DSC-T1, but it has only 5.Mpix. If you have model with telescopic lens it is probably damaged gears of lens.
Sep 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
How do i remove the lens? I need to chkeck the gears.
gears are incased not recommended to open lens assembly. need to order the whole lens assembly including the ribbon cables.
Jun 02, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Camera
Grinding or clicking noises generally means that the lens drive gear has been damaged. This usually happens if the lens gets hit (when the lens is in the out (operate) position), or if the camera is in luggage or a bag and the power button is activated by something else in the bag. If the lens does not have clearance to travel this could cause the gear damage.
These gears can be replaced but you will have to carefully weigh whether these older camera is worth the cost of repair.
Sorry! I hate giving bad news.
Nov 22, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Lens motor
check the gear box, maybe one of them is broken. Look carefully every gear this is a very common problem in this camera
May 03, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
419 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
