Question about Mitsubishi VS-50605 50" Rear Projection Television
Blurred words I actually have a Model vs-50610 and the words on the screen are blurry. How do I fix this?
  • bbcoolbreeze Feb 02, 2008
    What is convergence?
    President:
  • 4,402 Answers
Have you tried to do convergence?
Posted on Jan 31, 2008
  • Cary Farah
    Cary Farah Feb 04, 2008
    maybe it be best to have a serviceman take a look.
    Convergence amp ic bad
    http://home.earthlink.net/~oleg.filippov...
    http://cmpalmer.blogspot.com/2006/11/fix...
    http://www.hdtvoice.com/voice/showthread...
On power up there is nothing but blurring on display and viewfinder. Changed batteries multiple times with no effect.
is your screen blurry? or is it trying to focus on something and that is what you are seeing. if the words are coming up blurry or mottled it is a screen issue, if the lens is going in and out trying to focus but can't then it is a lens issue.
Jul 16, 2014 | Fuji FinePix S7000 Digital Camera
Blurry screen
First I will suggest you to start your system in safe mode by normally Pressing F8 key when windows starts up
In the safe mode update your graphic drivers just go the site of your system manufacture. Once there enter the model number of the system then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model
If this didn't help you then simply get the Intel software partner Reginout to fix all the errors which causing your screen blurs
Best of luck
Jun 19, 2013 | Computers & Internet
Picture is blurry like the tracking is off? what is the fix?
Your TV is out of focus. It is difficult to mention the whole procedure of fixing of blurred picture in VS-60707. It is a very long procedure & requires some instruments for adjustment. To make it easy for you please visit the following link & download 11 files. Although you see the download for VS-45607, the service manual is also for VS-60707. http://www.eserviceinfo.com/download.php?fileid=32177
First three files are archived in .rar format & rest are schematic diagrams in pdf formats. After extracting files from the first three files go to page no. 35 & adjust the focus accordingly
Aug 13, 2011 | Mitsubishi VS-60707 60" Rear Projection...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
The screen is white...
Sir,
This is the problem with dust. Reinsert RAM will solve problem. Avoid from dust.
Thanks
Good luck
Aug 17, 2009 | HP Pavilion dv9700t Notebook PC
Mitsubishi hd 1080 tv humming and blurred words/ bight colors
check the capasitor near the plyback value 250 volts and also the B+ capasitor
Oct 01, 2008 | Mitsubishi WS-55807 TV
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
IM HAVING A SLIGHT PROBLEM
You need service. Sounds like the convergence is out of adjustment. As the picture is formed by a tri- gun arrangement (one for each colour), if any of them is not correctly aligned, you will see shadows on any sharp line like text, or blurring on a picture. The shadow or blurring will often be one colour i e. red, blue or green.
Mar 27, 2008 | Mitsubishi VS-45609 TV
Blurred monitor image
Hi I just experienced the same problem.Could NOT figure out what went wrong.The LCD screen image was blurred and as a result the pics I took were blurry:(
My husband then took over and simply cleaned off the front lens and POOF! It is back to good!Hope this helps!
Dec 05, 2007 | Fuji Cameras
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
