ABOUT PHILIPS TELEVISION
I have a problem about my repair... philips tv, model: 14gx8510/71r has no power and the led light is always blink... and i change chroma ic, system ic, memory, but it just the same..i found chroma ic tda8361e there's is no 8volts in pin#36...
  • 281 Answers
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Posted on Feb 01, 2008
  • 21 Answers
Focus in Power supply section..check first if there is 14vdc in pin 1 of PWM IC..MC44603P...check Power FET.
Hope it will help you.
Posted on Apr 27, 2010
I have a Philips TV model 50FPF5332D/37. There is no picture and no sound.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location./
Apr 06, 2018 | Philips Televison & Video
SHARP TV MODEL LC-46LE830U WILL NOT TURN ON. I HAVE REPLACED THE POWER SUPPLY BOARD WITH NO HELP. IT HAS 2 BLINKING LED LIGHTS FOLLOWED BY 5 BLINKING AND REPEATING AGAIN. WHAT IS MY NEXT STEP?
It sounds that the main board fitted with your Sharp television is of Philips. Those blinks are fault indications, and you should follow the procedure of counting the number of blinks, as you do with Philips brand LCD TVs.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Sharp Televison & Video
Philips 37pfl5332d won't turn on. A blue light comes on and then turns red and blinks 6 times. Can I fix the tv or is it time to buy a new one?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Blinks counts to Philips Brand TVs are not direct' like other brand TVs. The details about how to count the fault blinks to Philips TV models are given in detail.
Mar 30, 2014 | Philips 37PFL5332D 37 in. LCD Television
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Philips 46PP9302 46in TV. power light flashes.
Sep 08, 2017 | Philips 46PP9302 46" Rear Projection...
Philips 42pf5521d - no picture, blinking green light
Aug 17, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
