Question about Toshiba TP61G90 61" Rear Projection Television
Toshiba TP61E80 blows fuse
I just got a toshiba TP61E80 for free a guy said it turned off one day and wouldnt come back on. i opened it up and noticed a fuse was blown. i replaced the fuse with the same one it asks for. and everytime it gets plugged back in it blows the fuse. i tried unplugging everything else from that board and putting a new fuse in and it still happens. nothing looks to be damaged on that board. has anyone had this problem? or is it something that is worth trying to mess with?
  • 3 more comments
  • brandyn Jan 31, 2008
    it is the closest fuse to the power cord.
    im pretty mechanically inclined but not so great when it comes to electrical... would i just check the power cord basically? and where it comes into the board? and across the fuse?
    would that just mean check the power cord and where it comes in to the board and across the fuse? im pretty mechanically inclined but not so great when it comes to electrical... i have a direct email to if that would be easier to communicate. Brandyn85@comcast.net. thanks for the help.
  • brandyn Feb 03, 2008
    i measured between the fuse clip for continuity(sp?) got no reading..im not the best when it comes to using a volt meter. but im pretty sure i did it right. i check alot of the resistors and they showed a reading when i checked both sides. when i checked the fuse clip, i also checked from one side of the fuse clip to one side of where the power cord connects, and there is continuity there as well, and the same thing when touch the other side of the fuse clip and the other power cord prong... is that normal? there is also no fuses in the board at this time...
    if thats too confusing i can try to get a picture of the board online. thanks for the help again. i really want to get this thing fixed.
  • Vista Electronics May 11, 2010
    What is the fuse location ?..............................T.
    Genius:
  • 1,694 Answers
Blows AC fuse on plug-in is a direct short in power supply...
check components with ohmmeter to find short....Check MOV
across AC line by measuring across AC fuse clip.......T.
Posted on Jan 31, 2008
  • Vista Electronics Feb 01, 2008
    Correct...with no fuse in clip and set unplugged,measure across
    the fuse clip.....if it is shorted,remove soldered in Metal Oxide
    Varistor ..Example = D899 hooked between AC cord and fuse.
    Install new fuse ...try again.....MOV is an overvoltage protect device....................................................T.
  • Vista Electronics Feb 03, 2008
    Please identify all parts by location ....F801 7amp, for example.
    D801,C811,812,813 and then on to the regulator Q801 should all
    be checked......you have a dead short somewhere close ..between the ac fuse and the regulator IC........T.
Suddenly blows fuse as soon as plugged in why?
Usually a fuse blowing immediately means there is a short in the amp somewhere.
Jan 04, 2013 | Koss KS2503 System
I turned the computer on this mornin, and noticed ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | HP Compaq FP5315 15" LCD Monitor
2000 Neon Fuel pump
engine light is on obd 2 scan for fault and fix gue$$ it is to much cost! it could be 1 of 20 things wrong scan it.
Nov 06, 2008 | 2000 Plymouth Neon
My deck wont turn on
Well i guess i have the same problem, thats why i rate this deck as Crap ass! Seems no one has a fixable solution
Feb 08, 2008 | Jensen VM9410 Car DVD Player
Wont power on
buddy of mine had the same thing, i looked in side and it had a fuse out. the tricky part was finding it. his had 6, two you could see the rest- well lets say you have to look and not play super man. works but i have to now find a way to re- fous it. any one how?
Nov 25, 2007 | Samsung HCM5525W 55" Rear Projection...
Toshiba 27A30 that blows Fuse
Jeff, If your not a technician please dont mess with the set as you can get seriuoly hurt by experimenting. And replacing a fuse that is black is only going to blow again and possibly cause more problems and damage the set more then it already is. Your problem is a shorted B+ rectifier or a capacitor or voltage regulator IC. If you don,t know what this is, or you don't know how to solder, as well as unsolder, Please seek out a pro to assit you with this repair. Good Luck
Aug 06, 2006 | Toshiba 27A30 27" TV
Televison & Video Logo
288 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
