MS-Dos running a file.. that keeps shutting down..
I am trying to run an MS-Dos.bat File but every time i does it shuts down is there any way to convert it so it will work on my system?
Comment by kammy86, posted on Jan 31, 2008 Or find a way to get it running.. and to stay up..
Comment by kammy86, posted on Jan 31, 2008 The file i'm using is to connect to second-life and permit outside sl client control.. but there seems to be some issues that i can't seem to solve on my own..
The batch file is suppose to open and load, and allow you to type in a username password, to connect w/o a client to second life.. and permit 'master' control, the console basically being a slave to whatever you set it for. and performing the command given.. etc.. i have a screenshot available of what it is suppose to do on the net, but some of my friends are having trouble and it keeps shutting down for them...
well what it is suppose to do is suppose to start the program and remain open.. the file i have is up for download at
http://www.mediafire.com/download.php?6agetzjnw22
  • kammy86 Jan 31, 2008
    I can't figure 'what' else to change.. heh I tell them to do that they claim they do and it shuts down for them..
    Novelist:
  • 171 Answers
Use Notepad and open up the login.BAT file. There are a number of things in the bat file which you need to change and replace with your own information!
Posted on Jan 31, 2008
6ya staff
SOURCE:
What happens wen rtc Batt is unloaded
Hello. batt files or batch files are used by your operating system to run a list of commands created by ms-dos or by you. A good example of a batch file is the autoexec.bat which is loaded each time the computer boots to MS-DOS. Batch files are like shortcuts on your desktop, when they are run they pass information through the command line and these sets of instructions run commands or programs on your computer. Did that help?
Feb 09, 2014 | Acer Predator G3620-UR308 - Core i7 3770...
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
ECHO
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
What is best website to show me dos programming examples.. want to creat an exe file to pick up text files from a directory and send them to a printer whenever a new file appears .(without pc...
you mean a .bat file that can be run when a new file is added. let me see if i can find a good site for you.
http://www.chebucto.ns.ca/~ak621/DOS/BatBasic.html
My advice is get a good book! One that stands out in my mind is "The Waite Group's MS-DOS Bible" (1991?) This will take you through using the command shell and batch files through how the DOS filesystem is structured, memory managment under DOS, an explaination of how the OS loads a program up to wrting little progams of you own using machine language and debug.
Another great book is Dan Gookin's "Advanced MS-DOS Batch File Programming" that will also teach you something about operating systems in general in a nice, unformal tone.
DOS also comes with a BASIC interpreter called QBASIC, that can teach you the funamentals of programming while augmenting your shell scripts and doing things that plain batch files just can't do.
www.animatedsoftware.com/faqs/learndos.htm
Aug 03, 2010 | Microsoft Windows XP Professional
I cannot run my ms-dos file batch when i double click it appear a note pad how can i execute it to run
first make sure the extension for that batch file name is for example:
mybatchfile.bat
The name has to have the bat extension. The type of file has to be a batch file with that extension of BAT
Then at that point you should be able to run it buy double-clicking it
Jan 06, 2010 | Medion MD 96340 Laptop
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
.bat file
All MS-DOS batch (.bat) files can be edited using Notepad. You may need to un-check Read Only in the file property if you wish to save.
Good luck and kindest regards.
Feb 09, 2008 | Acer S2W-4300U Flatbed Scanner
Right click on the file and select edit. This should load it in a text editor.
Now, simply read what it does.
You don't say what the batch file is for, so it's hard to say what you should look for in the file.
Jan 31, 2008 | Computers & Internet
MS-Dos running
give this a run...
put the file in your base drive (in C:/)
Start>Run> "c:">*insertfilename WITH ".BAT" at the end*
It will either work or just fail and leave the window open with whatever was displayed on the screen(hopefully, unless the bat has a "close window" command in the end of the file)
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Open Questions:
SBCglobal MAil CuStOMeR ?{1-/855+/*+536/*+5666/}#[email protected] SuPPoRt NuMbER SUPPORT NUMBER call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 12, 2019 | Best Computers & Internet
SBCglobal MAil CuStOMeR {1*!855*!536!*+5666}#[email protected]@# Service NuMbER IDAHO call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Computers & Internet Logo
115 people viewed this question
Ekse
Marvin
Marvin
