Dell Dimension 3000 PC Desktop
Problem for Dell Dimension 3000 PC Desktop
Upgrading RAM in a Dell Dimension Dim 3000
By One Wire on Jan 31, 2008
Hey new buddy, CoolDr. I see you are the computer guy, so I thought I would direct this one to ya. I have a Dell Dimension Dim 3000 with an Intel Celeron 2.4ghz cpu. I tried to upgrade my RAM from 512mb to 2gb (2 x 1gb sticks). I purchased them and they were the same specs except that the 512 in the computer said pc3200u and the ones I purchased sadi pc3200. The new sticks and the old stick all are 400mhz 184pin DDR. The only difference is that the old one has the "u" at the end of it. Does that make a difference, I have seen them listed on eBay in the same listing as pc3200 and pc3200u, so I thought they were the same.
Now the problem. When I install them, the warning buzzer sounds, like it does if the RAM is not fully seated. I have tried the 1gb sticks together and individually in each of the two slots, and same results everytime. I put the origional 512mb stick back in, and it works good (I'm using the computer now).
Anyhelp would be greatly appreciated. I bought the sticks off eBay and hate to be out money if the guy didn't have them listed right and they should have worked.
Dean
Comments:
Jan 31, 2008
- Thanks. The RAM I bought probably isn't compatible, even though it has the same information.
Does it matter that my origional 512mb states unbuffered and the new 1gb sticks don't have that u on it?
At least the guy I bought from says he guarantees satisfaction and will take returns on it.
If this one isn't compatible, I can always return to him and he has a more that he guarantees compatible, though I can only double my RAM with that one.
I appreciate your help.
Jan 31, 2008
- You mean that the ram installed together makes a difference. But it doesn't matter for the compatibility going from the old single 512mb and the two new 1gb. Now if these never work out and I have to just go with a second 512mb, I will have to make sure it is unbuffered, right?
Jan 31, 2008
- Nice, thank again for helping so quick Cool. I am just waiting to hear back from the guy I bought from. Worst case scenario, if he doesn't do a complete replacement, He charges a 5% restocking fee which isn't too bad. I just wish I new whether they were incompatable or just DOA. Again, I do appreciate it.
I hope you like answering a lot of pc questions, becuase as I come up with them they will be directed to you first, and if you can't solve it, then I will look elsewhere.
Dean
Same Problem
Jan 10, 2009
-   desk
top
? need to know will a Dell Dimension Dim3000
work with a ACP-EP MEMORY 1GB PC2-3200 DDR2 400MHZ 240-PIN PC DESKTOP memory DIMM
seeing as it's a pc3200 ?> -   Guest
Dec 13, 2008
-   Hi,
I have the same problem. I upgraded the original 256MB to 1GB.
Original Module: 256MB - DDR-400MHz-CL3 PC3200u-3033-0-a0
New Module: 1GB - DDR-400MHz-CL3 PC3200U-30330-B1 NonECC Unbuffered
The difference between the two is that the original module is single channel and the new module is dual channel. The BIOS setting for memory is in single channel mode and cannot be changed.
I thought the first module was DOA so I returned it to the store (reputable-Microcenter) and got another model (the same one) and I'm getting the same problem with the 6 beeps on POST.
Any help would be greatly appreciated.
Thanks.-   sbaldi
Best Solution
posted on Jan 31, 2008
Very Helpful)
CoolDragon
Rank: Wiz
Rating: 82%, 271 votes
It could be one of two things:
1) Bad Ram chip (different brands), mostly DoA when buying with fleabay.
2) the U on the chip means 'unbuffered'.
3) check the following responses from other forums (specially #5):
http://www.computing.net/hardware/wwwboard/forum/42718.html
Hope That Helps!
Comments:
Jan 31, 2008
- Actually it does, remember buffered ram is faster, so RAM is crucial that it has the same R/W access speed.
It's like cloning yourself, and both run 100 yard dash, one of you is on red bull, the other one is not (yeah, I know... BAD analogy).
Jan 31, 2008
- Correct, either both go buffered, or both go unbuffered. Don't mix them.
Jan 31, 2008
- Bring them on man, anytime!
If we don't know it, we google it.
Was this helpful?
Yes
No
Solution #2
posted on Mar 12, 2008
Somewhat Helpful)
djnick999
Rank: Guru
Rating: 87%, 73 votes
buy kingston ram not used cheap bs ram
Comments:
Mar 12, 2008
- or crushail sum mobos dont like all slots with 3200 speed sum lower them back to 2700 speed dont buy ones with u not made for yours
Mar 12, 2008
- and make sure non ecc unlesss u need that type of ram ecc server style
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 3000 PC Desktop
Questions and Unsolved Problems for Dell Dimension 3000 PC Desktop
Do you recommend Dell Dimension 3000 PC Desktop?
Answer
Answer
can not find lead or plug to connect to tower
Answer
Hello sir, I am surendra from Ranchi Jharkhand I am chip level eng. of all types mother board. I... (More)
Answer
I cannot get like super multi-blue (LG) to play blue ray disc
Answer
My Medion MIM 2260 will not start when when i push the start button, it was working ok yesterday... (More)
Answer
Why did you charge $4.99 on my Mmaster Card without my authorization? U want TB System Product... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repairmen
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
