-   Doreen1 just reiterated the instructions from the manual. What is an "ejector arm" and where do you stick the "plastic utensil"?-   Guest
Feb 26, 2008
-   our whirlpool side by side ed5ghexnb ice maker is not filling for ice but we can get water from the door not sure how to remove the tube to see if it has water in it on the back-   Guest
The ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open. Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line. Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position. New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production. Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice. Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil. Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure
OR
The water dispenser will not operate properly
Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.” Refrigerator connected to a water supply and the supply
supply and turn water shutoff valve fully open. Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
Kink in the home water source line? Straighten the water
source line. New installation? Flush and fill the water system. Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed. Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Side By side. ED2FHEXMQ00. Will not Cool. Compressor clicks to start, runs for 15-30 seconds, then...
(More)
Side By side. ED2FHEXMQ00. Will not Cool. Compressor clicks to start, runs for 15-30 seconds, then clicks off. Will Cycle this way yet no cooling. Fan is good, Coils are cleaned and setting at mid point on both freezer and fridge side. Prior to loosing all temp from fridge, could hear the thermostat click in at current temp as adjusting. Is overload or capacitor a problem on compressor. Compressor does get hot as it cycles. Let it cool and back to start, stop. with no temp change. Thanks for any assistance.
An ice cube got stuck in the ejecter fingers. Once I removed it the maker has not restarted making...
(More)
An ice cube got stuck in the ejecter fingers. Once I removed it the maker has not restarted making ice. This has happened in the past and the icemaker continued to work after the stuck piece was removed.
I have a whorlpool model ED25lf. What is the model number for the Kenmore equal model? I would like...
(More)
I have a whorlpool model ED25lf. What is the model number for the Kenmore equal model? I would like to compare prices under both names, but need the correct Kenmore model number that is equal to the whirlpool. My gut tells me that the Kenmore parts may be cheper.
i don't know what the model is on this side by side refridge . My son bought it about 4 years ago...
(More)
i don't know what the model is on this side by side refridge . My son bought it about 4 years ago and has never had the ice maker hooked up till just a couple weeks ago. It worked fine but now it won't push the ice out of the holding tray. It sounds like when you push the handle to get ice like it is not trying to turn the thing that pulls the ice to be pushed out the door. Do you have any advice without me going and getting the numbers? Thanks kathi
