Parts replacements i'm looking for the substitute for these transistors...A1011 and C2344.drivers for power amp. with 25V rail. or any complementary pair of possible drivers for this amplifier with 25VDC split PS. I'm using A1386 and C2750 power transistors. thanks.
    Scholar:
  • 54 Answers
This is straight from the 1989 Japanese Transistor Substitution Manual.......
2SA 1011--------use 2SB 1085 A, made by Rohm
2SC2344---------use 2SD 1562A, made by Rohm
Good luck...Rob
Posted on Mar 03, 2008
The type of audio power and the number on onkyo A917 amplifier
Hi
Usually there are 2 transistors for each channel, if you don't know the numbers on the transistors.
there is another way to get as close as possible to have equal or similar to the same type of transistors (NPN/PNP)
example: 2SA is PNP transistor.
there are (2SA/2SC) transistors and there are (2SB/2SD)
complementary transistors
1: you have to know the supply voltage for the transistors
2: choose transistors that it is equal to the current and voltage that suits the supply voltage.
follow this link to find suitable transistors.
be aware and be careful that there other parts you need to check on the power amplifier circuit, resistors,capacitors and drivers etc...
I would suggest (2SD1047/2SB817)
http://www.smcelectronics.com/DOWNLOADS/COMPTRANS.PDF
Good luck
Hope this helps
Jun 25, 2016 | Onkyo Audio Players & Recorders
Amp light not working and one dead right channel
Without knowing how it's actually laid out, I'd surmise the output amplifier transistors in the right channel are shorted, the fuse for that channel may be blown, and the speaker protection circuit is keeping it turned off. Most amplifier speaker protectors disable both channels if there is a problem, but yours could be different. I surmise the lights you mention are directly connected to the speaker protector chips and indicate readiness for normal operation. If it takes a few seconds for them to come on after power-up, that lends credence to my hypothesis.
Unplug the amplifier, open it up, and measure the resistance from the right channel output to each of the output power supplies (or to the fuse for the output power supply for that channel, if present). If one or both is very low (i. e, close to zero), you have a fried transistor. If that is the case, it is probably a good idea to replace the complementary transistor connecting the speaker to the other power supply even if it tests good; it may have been overloaded when the first one shorted. In many amplifiers, the transistors are inside a hybrid amplifier module, so you would have to replace the entire module. In some amps, you have multiple transistors in parallel; here you can probably keep the transistors that were in parallel with the failed unit, but I'd still recommend changing the complementary transistors.
Apr 23, 2014 | Volfenhag ZX-5168 2-Channel 4000W...
Is c1383 the equevalent of 2sd468
  • 2sc1383 can be substituted for 2sd468 provided you match the gain which is marked as Q,R or S on the 2SD part and B or C on the 2SC part.
Mar 07, 2014 | Nte D468 Equivalent NTE293 TRANSISTOR NPN...
I received a PV1500 amp that had only one channel working. i decided to open the amps to check the other channel being that i usually repairs amps. up on analyzing the damage circuit board of that channel,...
It seems there's another component (a capacitor, a diode, etc) causing a short circuit to triac and transistor, or there's an over voltage on this stage, please check if the voltage is according to the one feeding the good channel.
Mar 01, 2011 | Peavey Music
Where can i get power transistor replacement parts for my 960 watt 4 channel spl amplifier? two of the transistors are dead and i can find them anywhere. they are for the output transistors and the part...
they are a Driver Transistors 2SD718 & a 2SB688, these are Complimentary, PNP & NPN power transistors. try Radio shack, or your local parts supplier they are quite common and have replacements, equivalents too. google for them.
Jan 28, 2010 | Car Audio & Video
Would a 2N3055 make a suitable replacement for a 2SC1667 transistor? The 2SC1667 is from a Leak reciever - the main amp section they are used as the main amp.
Since the 2SC1667 is still available, why substitute. The exact part can be ordered. Substitutes are fine if hte original is no longer available, but you should use the original when you can.
Dan
Jul 02, 2009 | Audio Players & Recorders
ADCOM GFA 5802 POWER AMP NO SOUND, BUT POWERS UP.
Remove the output transistors and measure each of the sets of 3 pads and report the voltage readings here. I suspect that you have either a blown driver circuit or output transistors. The voltage readings will give me an idea on where to start looking for specifics.
Thanks,
Dan
Nov 11, 2008 | Adcom GFA-5802 2-Channel Amplifier
Kenwood basic M2 Amp Lightning strike
you can check the output transistors for short circuits with the low ohms range or diode checker . If they have failed, then it is often a good idea to replace all as much stress can be placed on an output array in this type of failure. to repair reliable, all outputs on an offending channel should be replaced.
Make sure the fuse you replaced was the same type of fuse. check markings.... T stands for sloblo... a fast blo duse may let go at turn on. The power supply may have a shorted rectifier diode in it also.
be aware however, every time a fuse of that rating blows... more damage may be occurring to the amp.
Dec 11, 2007 | Kenwood VR-407 Receiver
Power supply "Starmen TOD0851212" for my AKAI 20
If you can do it yourself replace C31 (1000 25v) also good idea to replace C32,35 also (1000 uf 25v). Theres also C33 (680 uf 25) if you want to replace it.
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
No Audio From Amplifier
I would first check for "rail votage" at the rectifiers... If all of your audio transistors are not getting around 40 volts then check the transistors you replaced. They should be getting a 5 volt (10 volt square wave is checked with a scope) "drive" signal. If half of your power supply transistors are not getting a drive signal then replace the kia494/tl494/kia594/tl594---whatever it is. thats the ic chip that supplies the "drive" signal to the power supply transistors. Also follow the board closely out of the power supply transistor to the 494 chip.. there should be some small driver transistors in between.. make sure they are not shorted or fried as well... let me knoe if you need more help
Aug 17, 2007 | Legacy Audio LA720 Car Audio Amplifier
122 people viewed this question
 Grubhead
Grubhead
