There could be a mismatch between hardware and the older systems. You may be required to have a 64 bit OS and/or X2 CPU and over 1G memory to access the current devices. XP is too old for many of todays advanced devices. In addition, the Old Bios may not have instruction sets to accmodate your Lan setup.
The WEP encryption code is configured in the wireless settings. If possible use WAP or WPA2 encryption as these are a lot more secure than WEP encryption.
WPS stand for Wi-Fi Protected Set-up .
According yo Wikipedia "The goal of the WPS protocol is to simplify the process of configuring security on wireless network, If your 2Wire router is equiped with that function it would be the BIG button on the bottom front of your router Look at this advertisement from 2Wire http://2wire.com/movies/pages/112.swf
You can prevent access from unwanted pcs configuring it on the security settings.
You can find step by step instructions on the manual, from page 27 onwards, available here:
http://support.2wire.com/view/765/2701HG_user_guide.pdf
Hope this helps,
Kind regards
by default, this gateway is using the WEP encryption, you can find the WEP on the barcode sticker on the gateway itself. if still can't connect to it. reset the gateway by pressing the reset button on the gateway for 8secs.. this will revert the gateway back to default settings.
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
