Question about Dishwashers
Bosch SHY66C My Bosch dishwasher won't fill with water.  All electrical connections are fine and I can hear it make a sound as if it is trying to start about every 2 minutes.  There was water in the bottom so I used a shop vac and pulled it all out but it still won't start and is doing the same thing.  I checked the solenoid with a multi-meter and it appears to be working.  My power went out last night for about two hours and that's all I can think of that might have affected it.  The dishwasher is about 1 yr old.  Any thoughts?
  • 1 more comment
  • tbdkmh Jan 31, 2008
    I saw another post and tried hitting the cancel drain buttons which worked for draining the tub so the drain pump appears to be working. Now it tries to fill itself and some water does come in but it sounds like a trickle and makes a gurgling noise when filling that I haven't noticed before. Even though some water is coming in now it still won't start a cycle and reverts back to the hum sound about every two minutes with water in the bottom just sitting there.
    Thanks for the replies. So do you know exactly where the float is on this model? There is no water in the pan underneath behind the kickplate. I'm not the expert but it seems that if the float was stuck, no water at all would come in as noted in my last update.
  • tbdkmh Feb 04, 2008
    Now I have replaced the fill solenoid and it fills up fine but the motor now want kick in for the wash cycle. I discovered how to pull off the error codes and I get an error code 2 which is for a pre-heater error on other models but I can't find any source for the error codes on my model. Anyone know?
    Sergeant:
  • 261 Answers
I'm a novice on this question, but i agree with the above statement about check the stuck float switch or check for a bad safety switch or lockout switch of some sort. I would suspect something is definately faulty in that area. Will the dishwasher run if you fill it up manually? Also, i guess the water does have to be preheated. Never thought of that. Sounds like the preheater isn't working. Check whatever switch or timer runs that. Also, have you tried turning off the breaker for the unit for 1 minute and let it reset? Try that first then try doing a reset on the unit itself. Mine has a reset button on the front. How about yours?
Let me know and good luck...Guru Jay
Posted on Feb 04, 2008
  • Jay Henderson
    Jay Henderson Feb 09, 2008
    How to Start a Stalled Dishwasher
    [Edit]
    You've come home from a vacation and discover your dishwasher will not work. You turn it to start and it just won't work. What to do. Call a serviceman? No. Try this first, before picking up the phone.
    Steps
    1. Initially check to see that the dishwasher has power, by checking both the plug to the washer and circuit breaker controlling the dishwasher.
    2. If the dishwasher has power and still will not operate, pour a fairly large pot of tap water into the inside bottom of the dishwasher.
    3. Close the door and turn it on. In most cases, your dishwasher will start and run normally.
    Tips
    1. The reason this method most always works is because, over time of non-use, your diswaher will lose it's "prime". That is to say that the water in the dishwasher water pump has dried out and requires "priming" for the pump to operate. Adding water to the bottom of the unit restores the "prime" and function of the dishwasher.
    2. Pumps do not require a prime in this application. Gravity provides the priming water by filling the collection chamber. More likely it is that the rubber seal has dried out and is stuck to the metal pump shaft, the water frees it by acting as lubrication. Try adding a little vinegar to the water in the bottom of the machine before leaving, that usually stops this from occurring.
    Warnings
    1. Since this method most always is successful, you won't be needing to call that service man, which of course won't be good for the economy, but very good for your pocket.
    2. On most brands you can also pull the lower front cover of from below the door and with the power off, try to spin the exposed motor by hand, Using a screwdriver, not your fingers.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Agree with djnick float is stuck.
Posted on Jan 31, 2008
    Genius:
  • 1,067 Answers
Maby kinked hose
  • nick helpap
    nick helpap Jan 31, 2008
    float is stuck in the over filled position
    or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time.
  • nick helpap
    Comment: My Bosch dishwasher was having problems filling. No fill, and the
    drain motor would continuously run.
    Help: After further investigating the problem, I noticed water
    in the base. I sponged out the water and the dishwasher reverted back
    to its normal working condition. I *think* the problem was a bad water
    fill value. After I removed the water from the base, I turned on the
    water and it would not stop running and flooded my kitchen.
Bosch SHE44C06UC/22 won't fill with water even though you hear water running somewhere.
Check to make sure there is no residual water underneath the unit, they have a flood sensor and if it is picking up water in the motor area it won;t run.
Jan 24, 2014 | Dishwashers
Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
Jan 23, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher SHE46C06UC won't fill with water
Check water inlet. Check for kinks in hose. Check the inline strainer in the fill solenoid. You say it makes an attempt to fill, is this because you can hear water trickling? If so I would suggest get to g the fill solenoid replaced as it may be blocked or not opening fully
Oct 27, 2017 | Dishwashers
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch SHX56BO6UC14 is not getting the dishes clean at all. It's making a grinding sound. It is pumping water & spraying water, but not getting anything clean. help?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 09, 2011 | Bosch Dishwashers
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
Spray arms not spraying and pump noise for Bosch SHY66C
Unless the motor and pump are an assembly permanently fastened as a unit, you probably need only replace the pump. Motors can be made really poor but will outlive the pump.
Since Bosch is a German brand, it may not be found on the Sears parts pages but it is worth a try. Just go to Sears.com and click onward for parts.
Jan 04, 2009 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
396 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
