Question about True TD-95-38-LT Beverage Cooler
BEER COOLER ICE PROBLEM
I HAVE A 3 COMPARTMENT COOLER MODEL TD-95-38 AND EVERY 2-3 MONTHS I HAVE ABOUT 1-1 1/2 INCHES OF ICE BUILDING UP AND RUINING MY BEER. HOW CAN I FIX THIS SO THE BEER DOES NOT FREEZE?
  • Anonymous Mar 22, 2014
    My water cooler keeps freezing up with a block of ice in it, what can I do to fix this?
    Director Badge:
    Uploaded 100 video answers.
  • True Master
  • 488 Answers
Three possible issues : 1st - it gets too cold (need to adjust thermostat; 2nd - drain line clogged (need to clear it somehow); 3rd - low on freon (might have small leak of gas). Hope thats helps.
Posted on Mar 01, 2015
First, dont overstock your beer, good circulation is key. Make sure your condenser coils are clean. Find a happy setting with the help of a thermometer to cool between 35 - 42 degrees. To defrost I put big zipl-loc bags of ice on top of beer. Turn temperature all the way up (the compressor will cut off but the fan will keep running) for a few hours. When the ice is thick i put HOT water in a squirt bottle and spray sections in the ice. Play around with that and see if it works. Hopefully you don't have a bad condenser. Good luck!
Posted on Jun 07, 2008
True TD-95-38-LT Beverage Cooler wont drain , cannot locate drain plug
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
Feb 01, 2013 | True TD-95-38-LT Beverage Cooler
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes the beer. is this a problem with the thermostat or something else?
This is probably the thermostat stuck closed and bad. Turn the tstat all the way to left or counter clock wise. The compressor should turn off.If the compressor continues to run the tstat is stuck and bad. A good replacement tstat would be Ranco # A12-1560.
Nov 08, 2009 | True TD-50-18 Beverage Cooler
Beer cooler keeps freezing
Could be but sounds like it may be low on gas. What emp do you set it at. Should be about 35 degrees if you have it set to low it will ice up on you. Russ
Jul 21, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Ice build up condensation will not drain down the tube to the catch pan under the refiridgerator. As much as 3 inches of ice will build up between the veg bins, causing mold builup in fridge, Model 550...
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Feb 17, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Beer box tempature control not getting cold enough to temp. specs
check the vendilation condition/temprature out of the freezer
Nov 17, 2007 | True TD-95-38-LT Beverage Cooler
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
True TD-95-38-LT Beverage Cooler Logo
527 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
