Question about Yamaha RX-V992
Yamaha PSR 600 - How to Open for Repairs
I have a broken board inside and need to open the unit.
I have removed the screws at the bottom, but cannot get top and bottom to separate.
Can someone tell me how?
Thank you,
Mitch
mitchp@sadako.org
This is an answer to a message left almost 2 years ago.
There are:
24 brass screws about 1/2" long.
3 brass screws about 1" long and
2 black screws about 1" long
In all, 29 screws to remove. The case should come off easily. Be careful not to disconnect wires when lifting back from instrument.
Posted on May 31, 2009
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
How do Ireplace dc power jack
Open up the keyboard, locate the power jack, remove board, turn over, unsolder, purchase new jack, resolder, reassemble.
Power jacks have a habit of tearing off the solder pad so you may need to bridge to a place further down the coresponding track to ensure contact is made.
The part you need is V6557600
www.beckettsmusic.co.uk
Aug 12, 2014 | Yamaha Music
My yamaha psr 420 has most of the middle keys not producing any sound when pressed. The others too produce an abnormaly high sound when pressed. Please whats wrong and how do i solve this problem?
Your key contacts have gotten dirty. Two contacts per key are used to sense velocity and if one doesn't work the sound will be full velocity and loud.
The contacts are conductive rubber "pills" in silicone rubber domes that the key presses down onto circuit board traces under the keys. Clean both the "pills" and the black portion of the circuit board GENTLY using ONLY 99% isoprophyl alcohol and QTips. There is a lot of disassembly required and one has to keep track of where the screws go and length and thread type to re-assemble after cleaning. Also great care must be taken to not damage the ribbon cablles connecting the top and bottom halves of the case.
Jan 11, 2011 | Yamaha NP 30 76 Key Lightweight Digital...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
I want to replce a couple of broken keys on a
Not familiiar with the PSR 6700, HOWEVER on the Yamaha Tyros the keys stay with the baseplate part. Once the top cover is removed, there are screws holding the segments of keys. The keys on the Tyros are in segments. As I recall the black keys are in two individual sections.
There may be commonality between the synths.
The keys press on a sheet of silicon rubber domes that have conductive "pills" under them. The restoring force is actually from the dome itself. Two contacts per key! BE CAREFUL to align the silicon sheet when re-assembling.
Jul 28, 2009 | Yamaha Music
PSR-2100 need to find replacement circuit board.
I don't have a parts source for these other than Yamaha. Call them up to get the part number for the board. The sound is usually sent through the headphone jack which acts as a switch when you use headphones. Replacing that board should resolve your problem. If the board is no longer available, it is possible to repair the existing one, but this is a specialty task and not one I would recommend a novice attempt.
Please keep us posted on your progress,
Dan
Jul 24, 2009 | Yamaha Music
Yamaha PSR 75
You have to completely remove the circuit boards. If this is the keyboard I'm thinking of then the keys are all mounted on the same part like parts on the sprue in a model airplane kit. If its a different one then you have to remove the assembly and take the spring of the key you want and at the other end when you flip it over there is a strip glued on the metal frame to secure the keys that you have to peel off for that sector.
Jul 09, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Belt is broken
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Yamaha RX-V992 Logo
341 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
