Question about HP Vs17 17" LCD Flat Panel Monitor
Input Signal Out of Range
My HP Vs17 17 in. Flat Panel LCD does not display anything when I start it up. Only the HP and Windows Logo appears beforer it goes blank. Then a message say "Input signal out of range change to __x___ __mhz" but how can I change settings when it won''t let me see anything on the screen? I've tried changing the settings in Safe Mode but it they won't change so what can I do????
  • 2 more comments
  • xccoach Apr 25, 2008
    I beleive a student changed the settings in my lab. However, the screen is black and that makes it difficult to go back and reset it. Oh for a little push pin reset button.
  • Anonymous Mar 31, 2014
    wen playing the league of legends game the monitor turn black and at the center, INPUT SIGNAL OUT OF RANGE CHANGE SETTINGS TO 1080x1024-60hz
    INPUT SIGNAL OUT OF RANGE CHANGE SETTINGS TO 1280X1024-60hz
  • 7 Answers
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Posted on Feb 20, 2008
    Problem Solver:
  • 19 Answers
I have an HP 1730 LCD monitor on a Compaq Presario S5100 desktop PC running Windows XP, up to date on patches as of 2009 Feb 25. For no apparent reason, the "input signal out of range" error message started appearing when the machine switches from boot mode (which looks OK) to regular windows mode. (My configuration does not HAVE a "safe mode" boot, by the way, so the usual advice doesn't apply.) Was the fault in the monitor, or the computer?
Step 1: see whether the computer is actually booting or not. Result: Over the home LAN, I was still able to access the shared directory on the suspect machine. This is good.
Step 2: swap the LCD monitor for an old Compaq MV720 CRT monitor. Result: the monitor does not like the input signal (essentially, the out-of-range error by another name), so the video signal IS faulty.
Step 3: reboot the PC with the analog monitor still attached. Result: the system boots up just fine, so there's something wrong with the way the PC boots with the LCD.
Step 4: swap video cables (without rebooting). Result: the LCD displays the working desktop, so the LCD display is still good, but there's still something wrong with the handshake between the LCD and the PC during boot. But we still don't know whether the LCD monitor is failing to produce the right Plug-and-Play sequence, as it used to, or the PC is no longer correctly interpreting the PnP sequence, so it's mis-configuring the video signal for the monitor.
Step 5: Back everything up, like you always should have been. (Always the last step, after a computer failure. ;-) )
Posted on Feb 26, 2009
Why does it say input signal out of range when I'm on the right setting?
Posted on Apr 15, 2009
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
Windows 8.1 Upgrade (Input Signal Out of Range)
It might not meet your system requirement I suggest you do a downgrade to your formal window version
Dec 16, 2013 | Computers & Internet
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
My Element flx 2210 shows "no signal" when it's turned on. Suggestions?
It looks like this unit will accept several inputs, and it is not autosensing (detects automatically)
On the side, there is a button that is labled "INPUT"
Push this several times until a picture appears.
The must be something attached to the TV for it to display a picture.
VCR, DVD, anything. If it does not see an input it will display
"NO INPUT"
Sep 29, 2010 | Element Electronics FLX-2210 22 in. LCD...
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
2,825 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
