Question about Dryers
Hotpoint Ultima TDL60P Tumble Dryer
No Heat although evertything is turning as it should.
I have replaced the heating element and the 2 thermostats but still no heat.
Could it be the drying sensor inside the drum that has packed up?
Help please, can't afford a new one.
Thanks
  • 4 Answers
U have some wires off
Posted on Feb 02, 2008
Washer dryer - dryer not heating up
Before you replaced the element did you test the receptacle for 240 volt? Did you turn off the breaker and turn it back on to reset it in case one side tripped and it wasn't visible?
Nov 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
I have a vented TL61P Hotpoint Aquarius tumble dryer which will not heat with or without the no heat button pressed !Could this be a thermostat problem or the heater ?
check thermostats as above posts have commented check also condition of elements as my dryer elements are cracked and need replacing just had a new belt fitted so reluctant to let it go
Mar 19, 2011 | Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Utima WD860
The error code F13 is indicating dryer thermistor open or short circuit.
This is located in the top of m/c, and it looks something like a thermostat wired in series with the element, if there is more than one, then it is advisable to replace both..
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
No heat
First thing to check are cutouts located above element. Should have continuity on both. take care element is fragile. Some models have a third located in the door space although this one is rarely prone to fault.
Nov 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Runs Cold no heat ? Tumble Dryer
Common faults -
Free tumbledryer repair videos
We have a Free full video library on appliance repair video’s
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
209 people viewed this question
Top Dryers Experts
Marvin
Marvin
