Canon PowerShot A75 Digital Camera Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It has a power and flash indicator on the screen displayed but the screen is blackout eventhough in shooting mode..
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on Jan 01, 2010
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86400
Points
1069
The Iris is stuck my frnd. you will have to get it repaired from a repairman
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Auto adjust flashes all time
davidfoun435, Possible that unit's internal power supply is about to fail! Go here first and do some reading: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Remember this! Your cold cathode fluorescent lamp, back-lit, lcd monitor isn't any different than any other brand in it's basic engineering design and mode of operation, and when "strange stuff" appears on the screen the first thing to investigate is the "switch-mode-power-supply"
12fixlouie
How do i get the OSD lock to stop flashing on my screen?
mcadams_alic, Mostlikely a problem inside unit. After visiting this web site: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ you may then understand why your unit is acting "strange"!!! Your lcd monitor isn't any different than any other brand in it's basic design and operation. When very strange stuff starts appearing on the screen of any CCFLback-lit lcd monitor the first place all lcd technicians would look will be the monitor's "switch-mode-power-supply!!!! hope this helps. 12fixlouie
7helpful
2answers
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
1helpful
Toshiba satellite a215s7422 screen blackout problem. computer powers up in safe mode and on an external monitor only. tried downloading display drivers and flashing bios-both failed (failed to find...
As you can see an image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
2answers
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
