Question about Mitsubishi WT-46809 46" Rear Projection Television
Is this a convergence amplifier problem on my Mitsubishi projection CRT? (w/ picture)
I have a picture of the screen here: http://www.austinthirdgen.org/gallery/d/9551-2/TVconvergence.jpg
The TV allows only blue and red adjustments, not green. So I can't adjust this.
Is this a problem with the convergence amplifier circuits?
Thank you very much in advance.
Lou
  • BigBabyLou Jan 31, 2008
    This TV belongs to my in-laws. The TV has not moved in years. All of a sudden, they said the picture looked "funny". I displayed the alignment grid and that's what it looked like (in the picture).
    Thank you very much.
    Lou
  • BigBabyLou Feb 06, 2008
    As I originally suspected based on the symptoms (and other posts on this website), the convergence amplifiers were bad. So after 20 minutes, the TV is back up and running.
    A simple Yes/No answer would have helped a little more.
    Thanks for trying.
    Lou
    Problem Solver:
  • 9 Answers
.. could you please state the occurence? is it after you have tryed to adjust something? or is it the was moved several times?
Posted on Jan 31, 2008
  • clark  daylan
    clark daylan Feb 02, 2008
    ..hi again.. the funny thing about troubleshooting is that sometimes we dig deep enough aiming to resolve what we should.
    if your unit was set for how many years now it might be a cold solder connections mainly in its printed circuit board in convergence and focusing circuitry. speaking of picture alignment likely in color are greatly affected by magnetic fields generated from focusing rings and or coils thus these coils could loose power to produce the necessary field. also if you can find the RGB color rays pls do check that all three is running fine. hav a nice day for you..
  • clark  daylan
    ..also pls not try adjust internal settings from trimmers, coils and the like just try to look for cold solder first.. good luck..
Mitsubishi rear projection picture that has a blue/green tint
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 01, 2011 | Sony Televison & Video
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi WS-55805 CRT projection TV with
This problem is most likely caused by damage in the convergence output amp IC's; this model uses STK392-040. Fairly common for various fuses that protect the DC supplies for these amp IC's to open as well.
Mar 03, 2010 | Televison & Video
My rear projection 51mp392h has color distortion on the bottom third of the screen,it curves up in the middle. Is this a picture tube
Hello tj444,
This is not a picture tube problem. This could be what is called pincushion distortion. It is caused when the is a malfunction in the deflection coils and the inability to correct for the curvatures caused by the CRT. The pincushion distortion can also be caused by the degradation of the functionality of the convergence amplifiers in the TV set. I would suggest that you have a TV technician examine the deflection circuitry and the pincushion circuit, this would also include the convergence amplifiers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red colour shadow in the picture
Hi
this means you need to replace the resistor or you need to replace the convergence correction amplifier IC...
Thanks!
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Coulor distortion at the top left of the screen
Hello jordan ashe,
This is an indication that the green CRT is having a convergence problem. This might be caused by the convergence amplifier or by the CRT. Does the rest of the picture look OK? and in addition can you supply a picture of your TV so as I can see what you are seeing and develop a proper diagnosis?
Thank you,
Shuttle83
Sep 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
50 " mitsubishi projection tv
This website:
http://www.techlore.com/forum/thread/18547/Mitsubishi-convergence-IC-s-used-in-the-differant-models/
says your model uses the STK393-110 convergence chip. Another site I looked at said that was a 6 channel amplifier so I'm guessing you only need one to repair your TV.
If you do some google searches on "stk392-110 convergence problem" you'll find some good sites that discuss how to repair the tv. The STK392-110 is a convergence amplifier that is used any many other sets.
Good luck.
Nov 19, 2007 | Mitsubishi VS-45609 TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
