Question about Xerox 5305 Copier
Streaks on copied paper
The copier is working well, except that I get streaks on the finished product. They seem to be in the same area each time. Its almost like something is dirty somewhere. I don't know if it is coming from the cartridge or somewhere else in the copier.
  • JGOMEZ5691 Feb 02, 2008
    I tried cleaning the drum but it didn't help. The streaks are still there. Thanks for trying.
  • Anonymous Feb 06, 2008
    I tried cleaning the glass and changed the toner cartridge but I still am getting streaks on my copies.
    Problem Solver:
  • 14 Answers
You have a failed drum cleaning blade that lives in the drum cartridge. The blade is replaceable as a seperate item.
Posted on Feb 10, 2008
  • 106 Answers
Open the copier,then remove the cartridge,posible that drum on your cartridge is dirty.
Posted on Feb 01, 2008
6ya staff
SOURCE:
Konika Minolta Magicolor 2480 MF streaks where the ink doesn't print
What color? replace that image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 15, 2014 | Konica Minolta Magicolor 2480MF...
Some time ago I found a couple of screws in the bottom of the copier but couldn't see where they came from. The copier is now making a grinding/ thumping noise and the copies come out streaked. Is there...
Not really it is best to get an engineer certified on the model of the copier you have to look at it a good engineer will no pretty much when thew see the type of screws and your streaking issue were they come from i would guess either the fuser area or drum area again this is a guess in the dark
Mar 06, 2011 | Canon Office Equipment & Supplies
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Toner streaks
You have to change a sensor. This sensor is on the left hand side of the machine. To know which sensor you have to open the left door and not take out the fuser. The sensor monitors opening and closing of this door. Make sure you change this one with a sensor that has the full black plastic. There is nothing worng with this machine except than this sensor.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Xerox 5305 Copier Logo
298 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
