Question about Mitsubishi WD62628 62" Projection HDTV
Wd-62628 video freezes, audio stops, 30 sec later TV shuts off
Our Mitsubishi wd-62628 has a random problem where the picture freezes and sound stops. There is no control at remote (can't change channels, etc). Then after 30 sec or so, the TV shuts itself off and the power/timer green LED blinks rapidly for 30-45 sec. Once that has stopped, the TV can be powered on again and works normally, as if nothing happened.
This may happen once a day, or once a week. It doesn't seem to have any preference of which TV channel it fails on (we only use over the air antenna signals). It has frozen/shut off while watching analog or digital channels. It may happen after an hour of use or after several hours of use. We first noticed the problem more than a year ago.
The TV is under an extended warranty. A local repair company contracted out by the extended warranty issuer came out a few months back and did a complete reset of the TV hoping that would take care of the issue. It did not. The same company just came out on Monday and replaced the E2P board (Mitsubishi part # 935d820001-v30, pwb-e2p v30). It had been 11 days since the last time the TV froze and shut off previous to them coming out. Now two days after the E2P board was replaced, it froze and shut off again.
The repair company is wanted to take the TV into their shop to try and reproduce the failure. But they haven't conveyed to me exactly what they plan on doing. I told them I am not allowing them to take the TV until they have discussed the problem with Mitsubishi and have determined EXACTLY what the next step will be.
Any help on what to tell them would be appreciated. I get the feeling they have no idea where to start, now that their two attempts to resolve the problem have failed. And as long as the TV works (at this point the problem is mostly a big annoyance), I am reluctant to let them have it, just for them to have it powered up in hopes it will fail for them. It could take WEEKS and the chances of them being there when it happens are slim.
    Scholar:
  • 87 Answers
Intermittent problems are the most difficult to find because they don't show up long enough to trace them down. Today the digital sets are all cpu controlled and a glitch from any board can lock up the set. The problem can even be software related, such as settings or firmware updates. Unfortunately we as technicians do not have a history of symptom/cause on the newer digital sets. Your best bet is to e-mail Mitsubishi with the symptom as described above, such as the blinks, E2P, signal source etc ... and ask them what they think. techservice@mdea.com good luck
Posted on Jan 31, 2008
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
Mitsubishi 65733
CONTACT MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO GIVE YOU AN IDEA OF WHERE THE PROBLEM IS WHEN YOU TELL THEM THE ERROR CODE, THEN LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi Televison & Video
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Vizio sv422xvt lcd tv , freezes shuts off and reboots at random, need fix advice, total reset didn't work
Sounds like you might need to replace the main board on the unit. Make certain you get the right one or it will not work. E-Bay might have one.
Oct 03, 2017 | Vizio SV422XVT 42 in. LCD HDTV
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
No picture after changing lamp, tv will not power up.
Try bringing up the menu. If you can't I'd suspect the fmt board if you can suspect the dm module.
Bill
Nov 24, 2008 | Mitsubishi WD62628 62" Projection HDTV
WD-62628 Mitsubishi DLP
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Oct 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd 62628 tv
After I reset the system, the Audio menu gave me access to the TV speakers that had been turned off. I turned them on and had to wire audio cabes from my sat box to the component audio in on the TV.
Sep 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
560 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
