Question about Bernina Virtuosa 160
Timing Lag. Hello, let me begin by saying that I have technical experience for sewing machines, just need a little advise. My problem is, the needle raises almost two millimeters before the hook begins to rotate giving the apprearence that my timing is slow. How should I correct this problem? Thank you.
  • Anonymous Feb 01, 2008
    Thanks for your reply, but I think you may have overlooked where I wrote that I have sewing machine experience, just limited on Bernina machines. Let me try and explain my problem again. The timing is, or would be correct if the needle and hook moved at the same time. My problem is that the needle lifts about two millimeters from it's lowest point before the hook moves at all. Maybe this will help you to better understand. This problem is very common in Brother and Simplicity machines. Thanks again for any help you can give.
    Genius:
  • 1,067 Answers
Are you sure the timing has gone,?
Check these first, needle in the correct way round, threaded properly, needle not blunt or bent.
If the machine still misses stitches arfter checking this then it needs retiming, select straight stitch, take off the needle plate, take out the bobbin case if you have a seperate bobbin case, and undo the two clips to take off the race cover, if you have a drop in bobbin just take out the bobbin, take the bottom off the machine so you can see underneath the raceway, tilt the machine back it will be easier, turn the balance wheel by hand towards you so the needle is going down into the machine then on its way back up, just as it starts to go up stop, look at the point of the hook, it should be just above the eye of the needle, if it is not undo the screws on the vertical gear underneath the raceway and you can move the hook round to where it should be, tighten and put the plate and parts back and test sew, if you have a front loading bobbin case undo the screws on the shaft of the raceway and move the hook round to where it should be, it may take you several attempts, if the machine sews perfectly on straight stitch test it on wide zig zag, if it misses stitches one side you will have to start again moving the hook either side slightly until you get it right thx nick
Posted on Feb 01, 2008
6ya staff
SOURCE:
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Begin sewing and machine doesn't sew it doesn't tie it off
Are you saying the needle does not pick up the bobbin thread?
Make sure you are using a brand new needle and that it is installed correctly in the machine.
If it still doesn't pick up the bobbin thread, the machine has most likely has been knocked out of time (happens frequently when sewing over pins or through particularly dense or thick fabric). You can search the internet for multiple web sites and videos that discuss sewing machine timing or take it for service.
Nov 19, 2016 | Sewing Machines
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
How do attach the walking foot Brother
Jun 26, 2017 | Sewing Machines
Needle Jammed
Please check the timing. And you go to mechanic shop or you ask the experience tailors.
Jan 30, 2014 | Janome Hello Kitty 11706 Mechanical Sewing...
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
Something is "clicking" while sewing machine is
Firstly eliminate the needle, put in a new sharp one. A blunt, bent or burred needle will cause clicking, popping or squeaking sounds.
If you can still hear a clicking noise, then it is possible that the needle is touching the hook when down in the needle plate, and this would indicate that timing is out slightly.
If you take off the needle plate and bobbin cover, foot and remove thread, then sew very slowly watching the needle and hook, you may be able to see/hear the point of contact.
I've never adjusted timing on my machines, always left it to a technician. But there is some general images on timing repairs at http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm if you are technically minded.
Oct 27, 2011 | Elna 2007 Mechanical Sewing Machine
I broke a needle on heavy fabric, I replaced the needle and the machine would not pick up the bobbin thread. I have THOROUGHLY checked and replaced the needle, needle placement, bobbin and bobbin...
-I know you already did what you can. It's frustrated.
How about try this:
When you want to sew thick material, make sure increase the foot tension.
-If the needle is broken, make sure replace with the same length needle. If the new needle is little long or short it will not pick the bobbin's thread. This is call off timing.
-If needle is same size then yes. the timing is off.
-I do not have any video to show you how to adjust, but you can watch in you tube. Just type " Adjust sewing machine timing"
It'll pop couple video there from others expert. so watch then you will have some idea how and where to adjust.
Good luck
Mai
Mar 14, 2017 | Euro-Pro 416 Mechanical Sewing Machine
Hello, I am wondering how to set timing or stop the needle from hitting the bobbin cam ... Any thoughts? Thanks! It is a Singer Touch and Sew 758
You are going to need a professional to do it, because it requires special tools and expertise. If, you don't have experience in it you can really mess it up.
Nov 12, 2010 | Sewing Machines
My needle appears to be striking against the bobbin case, any suggestions?
If your needle is inserted right, you may have a timing problem and it is not a do it yourself job, unfortunately because it requires special tools and know how. . Call Singer (1-800-4singer) and ask customer service and see what they say and they can best advise you.
Oct 10, 2010 | Singer 1525 Mechanical Sewing Machine
Pfaff Select 1540
Search for:
Lots of web sites and videos available.
Jun 28, 2017 | PfaFF Hobby 4260
Sewing Machines Logo
100 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Wayne Buss
Harjeet Singh
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
