Question about Kodak EASYSHARE 5100 All-In-One Printer
How do i connect my printer with a usb to a Ethernet (RJ45) cable
I bought a printer, but my wireless router doesn't have a USB port. I was seeing if it is possible to splice the printer usb to a ethernet (RJ45, Cat5) plug??? Or what colors go to which on the 2 wires.
    New Friend:
Is there is a way that we our-self can connect a fewmale usb to male RJ45 cable. Please explain the wiring...
Posted on May 13, 2013
    Novelist:
  • 103 Answers
Hi Tony,
I assumed you'd like to share the printer on network. I recommend to buy a printer server device that will connect USB port of printer and that device has RJ45 port that can be connected to router or switch hub to share the purpose. Hope this gives you an idea.
Best regards,
Rosener
Posted on Jan 31, 2008
6ya staff
SOURCE:
How do I connect my pc to my router? There is no ether port in the back. Can it be done thru the sub?
There are more ways how to connect PC to router in your case.
My assumption is that your PC has no Ethernet port.
  1. Use wireless connection. Activate Wi-Fi card in your PC and connect it to router by wireless network.
  2. In case you do not have wireless router or you prefer cable link you can buy an USB Ethernet adapter.
Some examples:
Anker USB 3 0 to RJ45 Gigabit Ethernet Adapter Supporting 10 100 1000 bit...
Cable Matters SuperSpeed USB 3 0 to RJ45 Gigabit Ethernet Adapter in Black
Jan 20, 2016 | Computers & Internet
My computer doesn't recognize my printer
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Dec 08, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Connect canon pixma printer to zyxel router
If the printer has wireless capability built in , no cables are necessary. Install the printer driver in the mac as a wireless connection. Connecting a printer to the router is pointless, unless you want to install the printer as a network printer, which would disable wireless.
Feb 20, 2018 | Actiontec Qwest Branded - Centurylink...
I have just purchased a Belkin N600 modem router. I have attached my Canon i850 printer to the USB port on the router but I cannot print. The green USB LED is not illuminated. Can you help, please? ...
I think you need to connect your printer to the router using an ethernet cable and not a USB cable. Ethernet cables are plug-and-play cables and doesn't require you to install a software. If you really need to connect your printer using a USB cable, you need to connect it to your PC so that the PC will run the installation wizard to install the USB cable. Of course the router cannot run installation wizard to the printer or the printer cannot run installation wizard to the router.
Sep 11, 2011 | Belkin Play N600 Wireless Dual Band Router...
My cable come through usb router wants ethernet connection
May be u can find a connector which let u to link usb to RJ45.
Nov 16, 2009 | Computers & Internet
CONNECTION LOCATION FOR PRINTER ON MODEL ET1161-05 EMACHINE
Ok if it is a usb connection then any of the usb ports
If its parallel then it shows that here too.
ethernet printers are usually attached to your router so that all the computers can use it and this would require a cat5 / rj45 / ethernet cable.
If it is wireless then yoo should run the software that came with it as
there would be no physical connection
If this information was of any use please click below
Aug 12, 2009 | E-Machines eMachines Desktop PC
Broken Ethernet Port
You say "your Ethernet Port" (= LAN port)
If unavailable try using any USB to rj45 adapter and you can use any USP port.
Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
Dec 28, 2008 | Linksys Wireless-G Broadband Router
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
Kodak EASYSHARE 5100 All-In-One Printer Logo
627 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
