Question about Apple iPod nano 3rd Generation
IPOD Nano Not working at all. Not able to turn on. Not able to HotSync.
  • 2 more comments
  • Anonymous Feb 02, 2008
    got wet on accident, will not turn on, menu screen showing but not responding
  • marvelite Feb 02, 2008
    not responding, got wet by accident, menu screen is showing but not responding, tried to reset but it didn't respond
  • Skyla Hays Feb 02, 2008
    my silver 3rd generation ipod nano has recently been unable to work. it worked before and now it doesnt work even if i tried everything(charge it, reset, it still wont work) it doesnt turn on.
  • Anonymous Mar 23, 2008
    My 3rd generation nano is only a week old and it won't reset, sync or power on. I've tried different USB cables and USB ports to negate a driver or cable problem.
    I really think I have defective ipod.
    President:
  • 4,402 Answers
Get a new cable if everything else works that is your problem
Usually, unplugging, replugging it and then rebooting solves the problem.
your other options are a driver issue..either with the ipod drivers, itunes, or the USB drivers for your computer itself. since your ipod video and psp work fine, you can rule out USB drivers, but that doesn't rule out additional driver problems.
the other option is there's some kind of failure with your ipod..and sometimes if a device starts drawing power before doing any kind of communication with the computer (like when my rockbox-hacked ipod goes into charge only mode) then windows will assume there's a hardwire issue. the best way to determine if it's an issue with your ipods are take them to another computer and see if they work. if they work fine...try uninstalling and reinstalling itunes (back up your music and database) and see if that solves the problem. if none of that solves it and you know the ipod shuffles are good..then your system has suffered from the mysterious driver failure that's plagued a lot of systems. and generally the only real solution is to reinstall windows from scratch.
Posted on Feb 04, 2008
Mp3 Ver: ld 3088 - std 1.1 does not recognized! help!
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
Feb 03, 2013 | Apple iPod nano 3rd Generation
Ipod wont turn on
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano. Hope this helps.
Jan 22, 2013 | Apple iPod nano
What is wrong with my ipod ao 5th generation
hope this helps
Sep 23, 2012 | Audio Players & Recorders
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
Won't turn on
Is your iPod fully charged? Sometimes the batteries become so depleted of charge that an accessory charger won't turn it on.
-Try plugging it in to your computer or a wall charger for a while, time will vary but it may turn on.
-If it is not turning on your computer will never recognize it, thus you won't be able to do a restore with iTunes.
-Try a hard restart as well this could help you.
Sep 02, 2010 | Apple iPod nano 4th Generation
HOW DOES THE IPOD NANO WORK!!!
You hold down the play/pause button until the Apple logo appears.
-Logan
Dec 20, 2008 | Apple iPod nano
Hold switch is disabled
You need to run the Restore/Recovery Tool
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 05, 2008 | Apple iPod nano
Ipod security code
There is only one way - and it will erase all your songs:
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work
with, your iPod nano automatically unlocks. If the computer authorized to work with
your iPod nano is unavailable, you can connect iPod nano to another computer and
use iPod Updater to restore your iPod software. See the next section for more
information.
If you want to change the screen lock combination and you can’t remember the
current combination, you must restore the iPod software, and then set a new
combination.
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod nano
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
How can I use iTunes to put photos on iPod nano?
"You can easily copy images from your computer to the iPod nano using photo sync in iTunes. Please note that you cannot import photos into iPod nano directly from a digital camera or media reader. If you connect an Apple iPod Camera Connector or Belkin Media Reader for iPod w/Dock Connector to iPod nano, you'll get a message on your iPod screen that says, ""The currently attached accessory is not supported by this iPod."" If you connect a Belkin Digital Camera Link for iPod w/ Dock Connector to iPod nano, you'll see a ""Do not disconnect"" message briefly, then the main iPod menu appears. For information on other iPod accessories that don't work with iPod nano, Some accessories that work with other iPod models won't work with iPod nano. Here are some items to note and the affected accessories: Photo Import iPod nano cannot import photos from an accessory (use iTunes to copy photos to iPod nano). It will not work with third-party card readers or with the Apple Camera Connector. If you connect such a device, you'll see an error message that displays for about a minute and reads, ?The currently attached accessory is not supported by this iPod.? Voice Recorders (Microphones) Like iPod mini, iPod nano does not work with third-party voice recorders. Apple iPod Remote Because iPod nano does not have a remote port, it won't work with any accessory that requires it, such as Apple iPod Remote. Headphones Port Location The headphones port on iPod nano is located on the bottom, therefore, it won't work with any third-party accessory that requires that this port be located on the top. No Video Out iPod nano does not support video out through the dock connector or the headphone port. iPod nano is not compatible with the Apple iPod AV Cable designed for iPod with color display (and iPod photo). If you need to use any of the above devices, you'll need to use an iPod model that supports the accessory. "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
