Question about Hitachi DZ-MV580A DVD Camcorder
Describe your Hitachi DZ-MV580A DVD Cant Read Discs ERROR 2881
Still getting errors, and can't use camcorder because I am unable to read any kind of mini DVD-R. Alway get Error code No. 2881. I've tried movin the lens housing to the left as one guy recommended but that did nothing, still getting Error. Can someone help. Got a newborn son and now it wants to stop freakin workin!!!!
  • surf243256
    surf243256 Jan 31, 2008
    I have the manual and already read everything the manual had to offer. Nothing in it for this specific problem.
  • surf243256
    Did all of that already as the manual indicates. The dealer is not doing anything for me. Tried all kinds of disks none work, even Hitachi recommended Maxell.
    Genius:
  • 3,422 Answers
here is the instruction manual for it,go through it carefully and u will find the sol.
Click here to download
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 31, 2008
  • 1 more comment
  • Priya darshan Jan 31, 2008
    You need to have adobe acrobat reader to view the manual in pdf format.
    Click here to download it if u don't have
    HERE IS SOME MORE USEFULL INFO:
    Disc error Hitachi dvd
    camcorder
    DVD camcorders were first launched by Hitachi,
    followed by other brands such as Sony,
    Panasonic,
    Canon,
    Samsung.
    The main selling point of Hitachi DVD camcorders
    is their ability to record video directly to a
    mini DVD disc (8 centimeters in size) and play
    that disk back on home DVD players. Hitachi recommend
    Maxell brand DVD discs for use with Hitachi DVD
    Camcorders and can record and play back a wide
    range of disc and memory formats including DVD-R
    DVD-RW DVD-RAM DVD+RW and SD
    Card
    . According to Hitachi there are 3 main
    reasons for not supporting other manufacturers
    discs:
    1. Some DVD discs may not work due to their construction.
    Possibly a disc has a very thin writing surface,
    one so thin that the DVD Camcorder laser cannot
    properly write information.
    2. Quality of DVD discs...some DVDs may be able
    to be written to, but will also peel and become
    defective within a short period of time. This
    can occur even within a year after writing a disc
    3. While some DVD-R discs can be written and finalized
    from Hitachi camcorders, they may not play back
    on all DVD players due to different writing surface
    depths.
    The only discs that Hitachi can verify as suitable
    for the Hitachi DVD Camcorders, for functionality
    and longevity and playback, are the Maxell brand
    discs.
    Finalize DVD Video eg. Rec. Disable, Format
    Error, C:13:02 1302 C1302 C:13.00 error
    We have specialist knowledge to Finalise DVD video eg. DVD Camera / Handycam
    / Videocam / Camcorder with problems of corrupt DVD or trouble playing mini-DVDs
    that occur particularly during the disk finalising process. The Camera displays
    disc access error message when DVD disks are not closed or non-finalised / unfinalised
    disc and won't play. Unlike other recovery companies we can transfer your video
    to be playable on stand-alone DVD players. Also repair Corruption of DVD-VR
    .VRO files recorded on DVD-RAM recorder and CRC Cyclic Redundancy Check errors.
    Trouble occurs with Corrupt DVD disk that won't play in either
    stand-alone video players or the video camera, or problem transferring DVD video
    files to pc or mac computer. We have the equipment to bring your lost files
    back. We recover video from dvd discs that have not finialized properly as well
    as unreadable, unplayable or corrupt dvd disks. Lost video clips, movies due
    to the Disk Error, Disc Error or Format Error message when you turned on the
    camera, or the mini DVD disc finalization was accidently interrupted. Also Rec.
    Disable, format error, error code 13, mini dvd finalize error code 1302, disc
    error unreadable disk.
    Data Recovery for CD DVD
    - Empty or 0 Bytes Capacity shown
    Sometimes a CD-RW or DVD-RW disk will only show as being empty or Zero 0 bytes
    capacity, even though you can see the data is burned to the disc. We can recover
    your Video, Photos and Data Files from such Disks.
    Typical DVD Disc Error messages
    Disc Access Error, Disk Access Error, Check disc error, Check disk, C error
    unreadable, disc error code 13, disk error code 1302, 13:O2 DISC ERROR, Disc
    Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised,
    Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD
    Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk
    not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD
    Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not
    correct disk, the disk in drive is not formatted do you want to format it now
    Well call the Hitachi service number at 1-800-448-2244 and tell them that u have
    a s disk read error. This model can not read DVD-RW. It can only read
    DVR-R or DVR-Ram.
    Let me tell u one thing these hitachi camcorders don't last more than a month or two. Almost 80% of the people who used this model had the same 2881 problem and it has not been solved by the company,they usually replace it or refund the money.
    So it is better u call them and ask what to do.
    Genius:
  • 1,067 Answers
EXAMPLES OF DISCS THAT CANNOT BE USED ON THIS DVD VIDEO
CAMERA/RECORDER:
Note:
Discs recorded on PC or DVD video recorder may not be playable on this DVD video camera/recorder: If so, message
“This disc cannot be used.” will appear. Also, blue thumbnails will appear (Fig. 1* on page 27), or normal playback will
not be possible.
DVD-RAM (2.6 GB) Ver. 1.0 DVD-ROM MO
DVD-R (3.9 GB) Ver. 1.0 DVD-Video MD
DVD-R (4.7 GB) for Authoring Ver. 2.0 CD-R iD
DVD-RW CD-RW Floppy disk
DVD+RW CD Discs other than those with diameter of 8 cm
DVD+R LD CD-ROM
  • nick helpap
    nick helpap Jan 31, 2008
    Error has occurred. Try to restart the DVD video camera/recorder
    using the following methods:
    (1) Turn power off, remove the battery or AC adapter/charger and
    reattach it, and then turn power on again.
    (2) Turn power off, and reinsert the disc. Then turn power on
    again.
    (3) See *3 on page 171.
    (4) If you have another disc available, check to see if any problem
    occurs with the disc. If another disc can be used normally, the
    original disc may be defective: Contact the disc manufacturer.
    If the above procedures cannot solve the problem, take note
    of the error number, and contact your dealer.
    Reference: “Error Code
SOURCE:
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
I have a Panasonic palmcorder, vdr-m30-pp, that keeps coming up with an error message 2881. I can't get past it to do anything and I have a bunch of mini dvds that have never been finalized. I want to...
that error is to do with the lazer lens that reads the disc, you can try a cleaning disc or using a can of comressed air.
it could also be a worn spindle, but that normally makes the mechanism noisy.
May 14, 2017 | Panasonic Palmcorder VDR-M30 DVD Camcorder
Error Code 2881 will not work
i put mine in the shop it is the laser and it cost $219.00 for the part because it comes in an assemlby piece it depends on how much they charge for labor. I choose not to fix due to high cost of it all it is in a bag besid emy computer
Jan 10, 2009 | Hitachi DZ-MV550 DVD Camcorder
Hitachi DZMV550A Error Code
PLEASE RESOLVED THE ERRO CODE NUMBER 2881.
Mar 13, 2008 | Hitachi DZ-MV550 DVD Camcorder
ERROR 2881
The manual is available online at: http://merchant.satisfusion.com/sf/library/manuals/owners/DZMV350_380A.pdf
This error is a read error-- try buying a cleaning disc and using it, or using a new, fresh disc. Likely the read/write optics are dirty.
Nov 18, 2007 | Hitachi DZ-MV350A DVD Camcorder
Hitachi-DZ-MV550A
eject the disk and if it it empty just open the cd door. with the lense to the left and the door on the top. look into the device. You will see to the left side a metal platform that houses the dvd laser. take and push the platform all the way to the left. The platform fails to retract once you do this you should be able to use a disk like normal provide you have a dvd-r disk.
Nov 26, 2006 | Hitachi DZ-MV580A DVD Camcorder
Error code 2881
Well Im going through the same thing and no one can seem to figure out what is going on. Ive tried all sorts of disc including a DVD-RAM Video 60 and Im still getting the same Error #2881 Code.
Nov 22, 2006 | Hitachi DZ-MV350A DVD Camcorder
Error code 2881
I found this problem only when I tried to use a RW disk. The camera will not use a rewritable disk. I reformated the disk in my computer but it still would not work in the camera.
Oct 16, 2006 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Hitachi DZ-MV580A DVD Camcorder Logo
851 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
