MS-Dos running I am trying to run an MS-Dos.bat File but every time i does it shuts down is there any way to convert it so it will work on my system?
  • 3 more comments
  • kammy86 Jan 31, 2008
    Or find a way to get it running.. and to stay up..
    The file i'm using is to connect to second-life and permit outside sl client control.. but there seems to be some issues that i can't seem to solve on my own..
    http://www.mediafire.com/download.php?6a...
    its suppose to run another file and remain open..
    the bat file only has. .
    cmd start TestClient.exe --first Jerry --last Republic --pass lar --contact "email@gmail.com" --masterkey "d6bdd01d-f171-4cc1-b297-1f2e6ee98bba"
    which is the base code which is edited upon using it to login..
  • Edmund Lorenzen
    Edmund Lorenzen May 11, 2010
    Depends on the bat file and what it's supposed to do... usually when a bat finishes it script it just turns off... I can help more if I know what the bat is for or if you post the file somewhere so I can download it or view it.
  • 58 Answers
Give this a run...
put the file in your base drive (in C:/)
Start>Run> "c:">*insertfilename WITH ".BAT" at the end*
It will either work or just fail and leave the window open with whatever was displayed on the screen(hopefully, unless the bat has a "close window" command in the end of the file)
Posted on Jan 31, 2008
  • Edmund Lorenzen
    Edmund Lorenzen Jan 31, 2008
    whoops missed something in what I typed before... "start>run> _CMD_>"c:">*insertfilename WITH ".BAT" at the end*"
    Sorry, But that bat you posted up there should only just runa program with a few parameters... I never seen any parameters to be run using a double - before.. You said it was for second life? I'll give it a run in a little bti when I install the game then.
What happens wen rtc Batt is unloaded
Hello. batt files or batch files are used by your operating system to run a list of commands created by ms-dos or by you. A good example of a batch file is the autoexec.bat which is loaded each time the computer boots to MS-DOS. Batch files are like shortcuts on your desktop, when they are run they pass information through the command line and these sets of instructions run commands or programs on your computer. Did that help?
Feb 09, 2014 | Acer Predator G3620-UR308 - Core i7 3770...
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
ECHO
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
I cannot run my ms-dos file batch when i double click it appear a note pad how can i execute it to run
first make sure the extension for that batch file name is for example:
mybatchfile.bat
The name has to have the bat extension. The type of file has to be a batch file with that extension of BAT
Then at that point you should be able to run it buy double-clicking it
Jan 06, 2010 | Medion MD 96340 Laptop
I M GETTING A RUN TIME ERROR....... WAT D HELL IT IS???????ND WATS D SOLUTION........
System Configuration Utility ( Msconfig ) is the Solution
click start and in the run box type msconfig go to the tab that says services and down on the left side there is an option that says hide all microsoft services do a check on it and then click on disable all
Nov 05, 2009 | Microsoft Windows Vista Ultimate Edition
Hi i'm A ojt technician of computer and I encomtered the problem of computer the problem is system halted... what is the possible deffect of that problem. . .
it cannot find COMMAND.COM
Explanation: When you boot up DOS, you are placed at what is commonly called the "C: prompt", where you can type commands or run programs. The part of DOS that reads what you type and executes commands is called the command interpreter, which is stored in the file "COMMAND.COM". This interpreter is loaded when you start the system or when you start an MS-DOS session under Windows 95, and is also reloaded in some cases when you finish running a program. In this case, the system was unable to find COMMAND.COM and therefore halted the system.
try this
  • Make sure that COMMAND.COM is in the C:\ root directory, or if it somewhere else, that there is a line in AUTOEXEC.BAT that reads "COMSPEC=X:\PATH" where "X:\PATH" is wherever COMMAND.COM resides.
  • Edit the PATH command in your AUTOEXEC.BAT file, if you are trying to run a command in another directory that should be accessible from anywhere.
please send me a feed back if this works out thnk you.
Dec 12, 2008 | ASUS A7N8X-E Deluxe Motherboard
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
MS-Dos running a file.. that keeps shutting down..
Use Notepad and open up the login.BAT file. There are a number of things in the bat file which you need to change and replace with your own information!
Jan 31, 2008 | Computers & Internet
Right click on the file and select edit. This should load it in a text editor.
Now, simply read what it does.
You don't say what the batch file is for, so it's hard to say what you should look for in the file.
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
