Question about Canon PowerShot S2 IS Digital Camera
Lines in every pictre ,
I CAN TAKE A PICTRE OUTSIDE OR INSIDE AND LINES ARE RUNNING ACROSS IT MAKE THE PICTURE NOT TAKE RIGHT .PLEASE HELP,I NEED IT TOMORROW.
Many compact digitals (of all brands) use a Sony sensor and Sony had a bad batch go through and the sensor's contacts are failing.  If you are getting images corrupted with lines, bad/weird colour or severe noisy hash, you may well have a dud sensor.  Check the canon web site for a list of effected cameras and/or contact Canon service.
Canon is replacing effected sensors free of charge regardless of warranty status.
Posted on Feb 04, 2008
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
The picture blinks black foe a sec. then back to normal pictre it has a 5times flash on the stanby bulb. book says akb?
5 blinks indicates faulty on c board (CRT base board) often a loose solder connection on RGB output amplifier.
Jan 11, 2011 | Sony Televison & Video
Hi, I have bought the Samsung LE40M86BD 40'' LCD TV around 2 years back.Last couple of days when TV is switched on pictre is not getting clearly, all vertical lines, glaring pixels appears all over the...
Kris it sounds like your T-con board could be failing
the t-con board is located in the top middle of the unit
try reseating the cable going to the board if you feel comfortable if not have it done by a tech
Nov 24, 2009 | Televison & Video
Hp 537 photosmart camera. my picture is frozen. i can,t access my previous pictures nor take any other picture. camera will flash but no new pictre is shown. please help.
Try to reset the camera - take out the battery then push the reset button with a straightened end of a paper clip. Hold the reset switch depressed for about 3 seconds. Reinsert the battery.
Sep 28, 2009 | HP Photosmart R707 Digital Camera
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
We have sound but no picture on Phillips flatscreen television
Take a flashlight and shine it on the screen when you have sound, look very close, can you see a video image? If so the inverter is probably bad.
Let me know and I will assist further.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 07, 2009 | Televison & Video
Screen pictre is to large
go control panel then click on appearances theme click on resolution the higher the resolution the smaller the picture
Jun 30, 2008 | Computers & Internet
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free (for the S1 IS), including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 18, 2008 | Canon PowerShot S2 IS Digital Camera
Toshiba 42H81 Red Vertical bar on right side
The symptom suggest a faulty converge ic.you need to replace that ic ( stk392-110 ).
Aug 06, 2007 | Toshiba 42H81 42" Rear Projection...
Olympus fe-130
This need looking at - Check Olympus Tech Help- especially if it is a recent purchase
May 22, 2007 | Olympus FE-130 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
