Question about Sony KV-XJ29M50 29" TV
Sony kv xj29m50 no picture.
Dear experts,
the sony tv xj29m50 lost picture with two blinks. replacing the h out with bu2520df make picture with normal sound until the picture mode change to dynamic mode. which makes the picture to shift to left side and the set to
stop with two blinks again[ h out still ok]. checked abl, akb and soldered all pc board make no difference.pls solve the problem at your earliest convenience.
best regards,
henry than myint.
  • henrytechMO Feb 03, 2008
    Dear Mergatroid,
    thanks for your attention. there is picture mode
    settings for this tv, dynamic mode set the contrast to max: automatically. by the help of your solution, i checked all resistors and found R615, which is in the line of B+ supply to Hout is high ohm. this makes the OCP transistor to conduct and
    cutoff the AFC line to shift the picture before shutting down the set.thanks again for your solution. I would like to rate your solution very helpful.
  • henrytechMO Feb 23, 2008
    dear sir,
    sorry for late rating of this very helpful solution. our e.mail line are barred so i have to use ultra surf for this rating.thanks again and god bless you.
    best regards.
    TMO
Hi all,
I need a service manual for this model (kv xj29m50).
Anyone have the copy??
Posted on May 08, 2008
  • 286 Answers
If I understand you correctly:
The horizontal output transistor in your TV blew.
You replaced it with a BU2520DF.
I'm not sure what you mean by "change to dynamic mode".
Dynamic what?
Usually, horizontal problems in TVs are caused by bad capacitors in either the sync circuit, the driver circuit, the geometry circuit or the output circuit.
When I repsir problems like this I use an oscilliscope to find which stage is not working properly, then start substituting the capacitors in that stage until the problem is solved.
Look for large orange or blue ceramic or polyprop capacitors with bulges or cracks in them.
Look for electrolytic capacitors with bulging tops or shrunk cases.
Check and make sure no resistors are brown, they may be blown.
Use an ohm meter to test low value resistors in circuit.
If you don't have an oscilliscopw, that's about all you can do.
Posted on Jan 31, 2008
Sony KV- XJ29M50 led flashing 2 time
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 07, 2012 | Sony KV-XJ29M50 29" TV
CAN WE CONNECT EXTERNAL SPEAKERS TO SONY KV-XJ29M50 TV
Check whether there is an audio out RCA type sockets at the rear side of the TVm marked as Audio Out. If so, you can connect these sockets to any exterenal audio amplifier, by connecting Av cable in between devices, and can listen audio from external speakers. Picture of AV cable is shown. Keep free its yellow pins. Use red and white.
Jun 08, 2012 | Sony KV-XJ29M50 29" TV
Sony KV-XJ29M50 top half vertical problem i.e shrink
Check and replace all electrolytic capacitors at its vertical output section. There will be 5 or 6 numbers. Replace all of them at the same time.
Apr 14, 2012 | Sony KV-XJ29M50 29" TV
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
The easiest way to identify the Vertical drive IC is to trace the horizontal Yoke coils to the board, the vertical coils to the board must lead to the vertical drive output where the IC is seen normally a inline IC with a heat sink.
Check if the solder joints are weak if so solder and check.
Jul 29, 2011 | Sony KV-XJ29M50 29" TV
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-XJ29M50 29" TV
TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
May 17, 2008 | Televison & Video
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Sony KV-XJ29M50 29" TV Logo
231 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
