Question about HP LaserJet 4300n Printer
Hp 4300 laserjet
I have a hp 4300 laserjet tha is giving constant paper jam. The jam happens just as the paper goes in the fuser assembly
  • comptronbah Jan 31, 2008
    Just to mention a new maintenance kit was put into the printer
  • Anonymous Mar 17, 2014
    paper jam on a Laserjet 4000
Did you reset the maintenance kit count after installing? You could still have a bad sensor.
Posted on May 20, 2008
  • HP Master
  • 1,113 Answers
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Posted on Jan 31, 2008
  • 1 more comment
  • Soulvisitor
    Soulvisitor Jan 31, 2008
  • Soulvisitor
    Notice that no tools are required, so you might as well have a look at the bits on your machine, see the 5 feed rollers, inside the centre you can see a plastic tab that one just pushes in and the feed roller slides right off the shaft, that you can see with cassette removed, there is also one on the cassete and another near the first, the cresent shaped roller, clicks into tray 1 feed, Back door of printer just comes out when you push on the tabs near hinge point on each side. then fuser is released by it's two blue tabs.
    oh and the other funny hook is for hooking out the old transfer roller (pictured).It lives in base of machine, remove cartridge and you will find him.
    If you have extra cassettes ie DTN or TN you can switch rollers from most used tray to least, but like I say you might well have a stuffed fuser. You can buy just fuser and just feed rollers, ie info link.
  • Soulvisitor
    Fuser is not installed fully, or fuser drive gear is faulty, would of been noisy pre kit
    jams on a single page?
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
HP Laserjet 4300 - constant print problems - error 13.01.00
You probably have a scrap of paper stuck in the feed where someone has janked a piece of paper out.
Nov 18, 2009 | HP LaserJet 4300 Printer
Hp LaserJet 3030
Make sure that the paper size is set to letter, not legal. Check this on the printer and the computer printer software.
Aug 21, 2009 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
HP LaserJet 4300n Printer Logo
259 people viewed this question
Ben Johnson
