This problem should be removed because:
Problem with Flat Panel Televisions
Vizio TV Stopped Working
Yeah, I know you hear that type of phrase a lot. Let me clarify. My Grandfather's L37HDTV10A decided to cease to function on Christmas. When you turn it on, it flickers very quickly, then merely displays a faded black screen. None of the control buttons will respond, not even the power (Remote and on TV), have to unplug it to turn it off. What part is most likely to have failed. I have already unplugged for 24 hours to clear its protection mode, but that didn't help.
Suggested Solution (3)
maybe its the Y or X Sustain its depends on your picture
You need to open up the set and measure the DC voltage on the backlight inverter board to see if you have the 24vdc after the picture goes out, if you do have the 24vdc, then the problem is in the inverter board, if 24vdc is gone then it will be in the power supply. parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=l37hdtv10a&limit=200
try 0178
the remote for Cable Box to control my Vizio
0178 32" but I am sure they are all the same
others for Vizio
1758; 10178; 627; 502
Source: vizio tv remote code
vizio tv remote code l37hdtv10a and how to do it please!!!!!!!!!!
37 inch vizio has black screen. the vizio display
37 inch vizio has black screen. the vizio display on front comes on.
Vizio L37HDTV10a, No picture, Sound works fine.
Have a Vizio L37HDTV10a, had it for 3 years, was wallmounted in the pool room but was out of reach of sticks. Power indicator is on, sound...
vIZIO l37hdtv10A, NO SOUND, PICTURE WORKS FINE
My grandfather has a Hitachi
My grandfather has a Hitachi 50ux58b and is having double vision or shadowing -- whatever it's called and redness color fading-like. ...
what to do when vizio tv powers up only to Via...
after powering down, the tv powers up only to the Via dock screen. NO other functions work.
toshiba 19DV615 unlock region code
Can anyone help?
Fix-O-Meter
108
108 people viewed this problem
- 0 people are following this problem. Be the first!
Top Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
