Question about Zenith P42W24B 42 in. Plasma Television
Zenith p42w24bx i am missing the bnc-rca adapter. i tried to use an rf adapter but got no picture or sound from cable box. my dvd player works with s-video and rca cables- the picture has interference and the screen flickers- is this monitor worth fixing/
    Genius:
  • 1,067 Answers
U can buy tose on ebay set of 10 for 20 bucks gold bnc adpoters ok
Posted on Jan 31, 2008
How do i get my Panasonic ct1388yd to register it's picture and its sound of my game console
The modulator is outputting channel 3 or 4 analog not digital. Channel 3 digital is not channel 3 analog. You have the opposite problem of those trying to receive TV on an older Analog TV. You need to rescan your channels to add the analog input. Assuming you TV still scan for those like mine does.
P.S. - BNC!!! Really?? I only see those on security systems these days.
Apr 16, 2015 | Sega Video Game Consoles & Games
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Jan 02, 2015 | Televison & Video
Th-42pwd8uk has green light and sound and no picture
Why would you use composite video? It's very low end., subject to interference. Change to HDMI.
Mar 30, 2014 | Panasonic TH-42PC77U TV
Connection to cable to TV
you need to connect using rca leads , the tv should have at least 2 rca inputs . it is not possible to see 2 pictures if you are using rca leads. it seems to me you are using rf outputs or have used rca and joined them with a joiner which will cause the problem
Apr 05, 2013 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I have a green screen but I can hear the sound. Amovie plays in the dvd player but the picture is green when I try and watch the cable. Please help.
I take it your DVD is plugged into your Video in and your Cable is plugged into your RF connector or Antenna input. IF this is the case, you might have a bad RF cable. Can you run RCA cables from your Cable box to your TV? This should help with quality of picture as well as better sound. RF Connectors are old school. In todays market, they don't need to be used anymore. I don't use my RF connectors at all. I hope this helps you.
Jan 06, 2011 | Mitsubishi WD-60735 Projection Television
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Zenith P42W24B 42 in. Plasma Television Logo
222 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
