Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
Vacuum doesn't go into carpet mode
Hi, I have the boss 4d model vacuum and the brush isn't turning and it won't go into the carpet mode. I looked at the belt and it is on, but it isn't turning so I don't know what the problem could be. Please help.
  • frustrated01 Feb 09, 2008
    Brush motor won't come on after sucking in a sock. Removed sock and still won't come on. Unscrewed bottom and saw nothing else wrong. Nothing happened when punched motor reset button--still won't turn on. Any trick to this?
  • Anonymous Feb 26, 2008
    the brush does not start turning when you turn on the vacuum, but there is definitely suction.
    President:
  • 1,673 Answers
If the model number is 5892AVZ, either the brush roll is bad or the brush roll motor isn't coming on to drive the brush roll. There is a circuit breaker, make sure it didn't trip, reset it if it has.
Posted on Jan 31, 2008
I have a eureka 4D boss vacuum that won't go into barefloor mode and has no suction in carpet mode
turn the beater head over and see if something is stuck ours was totally plugged with stuff till I cleaned it last week for wife .
Dec 24, 2015 | Eureka Vacuums
Troubleshooting
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
May 01, 2010 | Eureka 5856BVZ Boss Bagless Upright...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The boss keeps shutting off
take the brush roller completely out of the vacuum then plug it in .you should be able to hold on to the ends of the brush roller and turn the brush freely if not the brushroller is froze.try taking the ends off the brush roller an see if you have carpet strands or hair built up around the spindles
Mar 22, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
THE BOSS SUPERLITE THE BRUSHES WON'T TURN
Check two things with this model: if the top slider button has been activated it will turn the brush roll on. If not then you'll have to remove the sole plate and check the sides of the beater bar - sometimes this will get jammed and refuse to turn because clogging of dust or tangled hair/carpet thread takes up the thread wheels at the sides. Sadly this model has a permanent toothed drive belt that can't really be replaced by the owner. However check the slider control on the top of the main body / handle first before doing anything - as you know it has a two option slider - switching on without the brush roll function and switching on with the brush roll activated.
Feb 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Mar 08, 2008 | Vacuums
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
430 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
