Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop My laptop became unplugged from the power source and ended up dying as it was out of power. Can you tell me how to get my laptop back up and running - thanks
  • 24 Answers
If it won't power back on after plugging it back in, try this: remove the battery and leave the laptop unplugged. Press the power button for a few seconds then release it. Put the battery back ni and plug the laptop back in. try to power it back up. If that still doesn't work, look for a "reset" hole near the power switch that you can stick a straigtened paper clip into.
Posted on Jan 31, 2008
6ya staff
SOURCE:
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Toshiba Satellite Laptop screen went black
You may try this. Unplug ac adapter and remove the battery out. While the laptop is off and without the power sources, hold the power button 10 secs. Put the power sources back and turn it ON.
Mar 10, 2011 | Computers & Internet
No character appear on the screen when tunrn on the power
Unplug AC adapter (charger) and the battery (located on the bottom).
Without any power sources, hold the power button 10 secs.
Put the power sources back and turn ON the NB.
Mar 10, 2011 | Toshiba Computers & Internet
My toshiba laptop overheated and now it won't power on
Is the ac adapter, battery and power indicator light illuminated?if it is.
Try to unplug the ac adapter (charger), remove the battery(located on the bottom) and without the power sources (w/o battery and ac adapter), hold down na power button 10 secs. Put the power sources back and turn ON the laptop.
Feb 27, 2011 | Computers & Internet
My keyboard can't use after charging
1.Turn OFF the laptop, unplug the AC adapter and remove the battery.
2. Without the battery and AC adapter, hold the power button 10 secs.
3. Put the power sources back and turn ON the NB.
4. Test if the keyboard is already working.
Feb 27, 2011 | Toshiba Tecra TE2300 Notebook
We have toshiba satellite pro laptop which was working fine. Now it will not turn on and the caps lock, f10 and f11 lights are illuminated even though laptop not turned on. Nothing happens when we press...
Remove all power sources.
Remove hard drive and Ram.
Fit AC adapter and press on. If the laptop complains as there are now no periferals, power down the laptop.
If it still dosn't power up at all, you have a motherboard fault and cannot continue. A Toshiba Computer Repair Cetre will help you out.
If it did work;
Disconnect power source.
Fit RAM and try again. If that still works but now states that there is no OS, power it down and with power source removed fit the hard drive.
Power up again with AC Adapter. Hope fully all now should be well or at least you now know where your fault lies.
I hope that helps.
Dec 30, 2010 | Toshiba Satellite A60 Notebook
Charger -chirping noise
it sounds like the capacitors in your charger are starting to give out. I would buy another.
Sep 03, 2009 | Toshiba Satellite U305-S7477 Notebook
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
I have a p35-s609 can not run on AC power, lits in front on,ok battery charges but when dies it will not run on the AC power. Also when you turn off the the button stays blue and you can not start back up...
usually when you have power problems are associated with a dying battery.. have you tried replacing the battery? there's no much you can do besides replacing the battery, getting item serviced (which may cost as much or more than the laptop (if old) or getting a new laptop.
Sep 26, 2008 | Toshiba Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
