Question about Raymarine E120 GPS Receiver
Ray Marine c120
My 120 was on and died and will not come back on checked the fuses and wires no luck only 1 year old. any ideas??
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Posted on Jan 09, 2009
It sat all winter and most of the summer&wouldn't start so I bought a new battery,spark plug&another fuel pump Bc the old one was corroded over
Try running sea foam through ur system take the gas hose off the tank make a funnel system to that hose fill it with straight sea foam crank the bike untill it sucks at least 1 cup full let it sit for 24 hrs then try to start the bike with gas by adding through the funnel still no luck check spark plug for spark if no spark check sensors a wire could have croded and not making good connection also check your fuse box changing fuel pump could have blowen a fuse
Dec 01, 2015 | Motorcycles
The elements only work if the fan is turned on. And they do not get real hot and the fan does not go full speed why is that?
Bad wiring. I'd guess you are trying to run the elements via the fan! Double check your work. This could be a very dangerous situation if not to you, those near you.
Apr 01, 2015 | Kitchen Ranges
GE JEM25GY Spacemaker died. No lights and won't turn on. Power from recepticle is OK. Shall I just buy a new one. Probably had this one for at 15 years. Thanks
Jerald,
It may just be a blown fuse. At 15 years old it might be a good idea to consider a new one but replacing the fuse is not real expensive and fairly easy to do. Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 07, 2015 | GE Microwave Ovens
Kodak carousel 600 slide projector thermal fuse replacement
If the FUSE is still available (this model could be as much as 50 years ago!!), the fuse is wired into the 120 volt circuit near the projection lamp. Check with: www.micro-tools.com
for availability. good Luck!! Jim
Feb 22, 2013 | Kodak Carousel 600 Slide Projector
I have a Maytag Quiet Series 300 dishwasher that is approximately 2 years old. It has been working fine up until now. It has no power at all, no lights etc. I have checked all the power breakers and...
This dishwasher does not have an internal fuse in it unfortunately. Check for power to the dishwasher and if it definitely has 120 volts you need to order and replace the touch control at the top of your door on the dishwasher. This part common fails and cuts power to the entire unit.
http://www.appliancerepairlesson.com/
Good luck
Mar 02, 2011 | Maytag Dishwasher
Keep blowing ECM fuse on 90 honda accord
I'm thinking the ECM is bad and grounding out, causing the car to blow the fuse. The old gas wouldn't cause this problem.
May 27, 2009 | 1990 Honda Accord
I have a rheem furnace. A week or so ago, we had a burning smell, and the furnace shut down while I was gone. When I came back, it did start again, but the smell was still there. I called a guy who came...
Your control board may have a problem. When the burner fires up, after a time delay of about 45 seconds, you need to use a voltmeter and see if the terminal marked H for heat has 120 volts coming off it. This voltage will be the power to spin the blower. If ther is 120 vac at terminal H then the blower motor or cap. is no good. If there is no 120 vac then you may have a bad control board.
Jan 03, 2009 | Heating & Cooling
Cobra 148
For most CB radios, some common components that fail and would cause a fuse to blow would be:
1. reverse protection diode located right after the power connector at the very rear of the board;
2. finals (2SC1306/7 or 2SC1969);
3. filter capacitor, 2200uF/16V;
4. audio amp IC located on the side of the chassis; and/or
5. 3 terminal voltage regulator (780X) or a zener diode.
Alternately, a wire (after the switch) might have been grounded.
Hope this be of some help/idea. Post back how things turned up or should you need further information.
Good luck and kind regards.
Nov 04, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Raymarine E120 GPS Receiver Logo
236 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
