Question about Panasonic AG-DVC30 Mini DV Digital Camcorder
Intermittent audio problems from mic jack
I've tested several mics with my ag-dvc30 and with other cameras and determined that the problem is with my mic jack. For instance..the other day I shot an interview and the audio was fine. I used ac power and a Rhode video mic. I moved the camera into another room and shot another interview using the same setup. The audio had a constant buz...until I zoomed in for a very close-up! Then the buz disappeared.
I cannot hear any audio problems from my headphones. It isn't till I play the tape from a deck hooked up to a good sound system that I can hear the results. I've done test after test with various mics but cannot isolate what is causint the bad audio and what makes the audio okay! Could a technician figure this out...even if he checked it out on a "good" day?
Also - If I were to find the xlr adapters for this camera - could I expect the same problem? I know they connect to a dedicated port but would the audio problem carry over to the xlr adapters?
K
  • Kay Anderson Jan 31, 2008
    Joe -
    Thanks for the quick response. A few questions...Is thee a way to actually diagnose the problem? I mean, can a techniciat say for sure that the problem is in the jack or not?
    Is it fixable? If so...can your recommend a place in the Toledo, Ohio area. I see you're in Memphis.
    I'm not using the xlr adapters because I can't find them anymore. If I could find them, and I had one of the audio problems you suggest, would the sound from the xlr's be just as inconsistant?
    It's possible that this camera had been dropped more than 1 time. The person I bought it from left a tape inside...showing him and his buddies doing "xtreme sports" skateboarding and whatnot!
    Kay
    Sniper:
  • 80 Answers
This camera has a history of problems with the audio encode/decode process IC which causes loss of audio input and distorted audio processing. Most noticeable is the loss of audio packets in playback of pre-recorded material.
If your problem is in the mic. jack I believe you would be hearing the buzz while monitoring with the headphones. Also, if the camera has been dropped, the audio I/O board connector can break away from the main board causing a bad ground loop or loss of phantom power, this is a common problem.
Hope this helps in some way,
Joe Weibel
customelectronics.org
Posted on Jan 31, 2008
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Recording Audio via the Audio In/Out
If this camera come with a Mic input or audio in put you will need to use a seperate amp. or use internal.
Dec 06, 2007 | Panasonic AG-DVC30 Mini DV Digital...
My external mic wont work! Please help.
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
Jun 05, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Aiptek GSV 1080P HD Camcorder external mic feature won't work.
Possibly an impedance mis-match - check in both manuals.
Sep 27, 2017 | Video Cameras
AG-DVC30 "no tape in camera" error message
thats probly the cass in swicth
or a dirty sensor....
hope that will help..
Mar 01, 2010 | Panasonic AG-DVC30 Mini DV Digital...
I try to record a video with my web cam and it has no audio
Hi, first of all you need to make sure you have the microphone configured properly. If using the cams built in mic you need to make sure it works . If using XP Open the control panel and click the sounds and audio deviecs, click the voice tab, there you can select which Mic to use: the USB cam mic or another mic , then click test hardware. If you should see a mic playback test. if the level is there then the mic is working. next see if there is a mic level test/adjustment within the camera software, if using skype you also need to set it up and turn up the Mic level there too. you may need to add a mic, some USB cam built in mic aren't that good. you can buy a cheap mic and plug it into the pink jack.
hope this helps, please leave a 5 thumbs up if this helped
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Facebook Social Network
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Mic level problems
There is a small switch on the front side of the camera ( the lens side) make sure that it is set to mic (Input 1)
Hope this helps.
santhoshcj@gmail.com
Jan 31, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Mic input
have seen a couple of these cameras with this problem.  a defective board inside the camera is the culprit. the board itself costs around $500 plus the labor to replace it.
Sep 24, 2007 | Panasonic AG-DVX100A Mini DV Digital...
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG-DVC30 Mini DV Digital Camcorder Logo
150 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
