I replaced the drum after your great advice a month ago now I need to replace the cleaning brush for the drum but I have it all out and can not figure out how to release the brush. How do I get it out?
Replace the drum blade by removing drum unit and sliding out-cam developer unit with black lever on rh side of copier. remove toner waste bottle first.
drum blade comes out after popping off upper plastic cover, on front of drum unit move spring to right and take off spring which exerts tension on the blade!
BEFORE removing blade remove the drum carefully{dont scratch} with screw on front of ***'y turn t-post 1/4 turn and pull out.
blade comes up and out after pulling front side plastic retainer/tension piece out.
vacuum unit with hepa filter vacuum replace blade with new one & re-assemble-if you can locate starting powder I always powder the drum on new blade installs.This will reduce streaks in the future.
you should be able to get starting powder from precision roller.com
Need any more help just holler!
Why in the world are you replaceing the brush? In 25 years of copiers, i,ve never had to replce a brush. If its streaking on the copy, its the blade thats bad. only reason to replace a brush is if its broke,cause of a clog. just vacumm it out.
