Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
56" jvc projection
What is broke when there is an arc on the top and bottom of the screen?
  • 579 Answers
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Posted on Jan 31, 2008
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc projection tv
try this site http://www.sharefx.net/index.php
Jul 16, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Easyab
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
BLACK ON SCREEN
High voltage problems..Anything from bad regulator capacitance, to defective flyback transformers....accordianman
Feb 27, 2008 | JVC AV-56P575 56" Rear Projection...
56"wide screen
Have you tried to adjust the convergence? If you can't get them to line up then you may need to replace the ICs.
Jan 30, 2008 | JVC AV-56WP74 56" Rear Projection...
How can I fix my 56" widescreen jvc
ok. let start this process. are the colors seperated? RED GREEN BLUE Then this is suspect will be a convegence problem. which 85 percent of the time is what is know as convergence ic chip failure. a electronic part replacment. are you a tech or know how to solder. any experince would be helpful but i would have to admit this really is not a job for non techs there are setup issues. at our shop the cost of such a repair averag 135 to 250
Jan 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Broke
Sounds like maybe the convergence chips are shot
Oct 06, 2007 | Zenith IQB56W10 56" Rear Projection...
JVC I ART
You need to replace the convergence IC's. That is the most common issue with any CRT type projection TV.
Apr 06, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
