Question about Panasonic PT-53WX42 53" Rear Projection Television
53"panasonic television my television i have problem with my color all of sudden it shows more red and it looks like a shadow or double what can i do?
  • henry0 Feb 08, 2008
    I have the same problem but the color is blue instead of red.
    I have opened the back and cleaned the dust out and tried to adjust the lens of the blue picture tube but it only gets worse . when i cover up the blue lens the color gets better but there is more of a green tint to the picture and i cane not adjust it. i need to know where i can get this replacement part and if there is any risk in changing this part myself?
UPON POWERING UP, MONITOR STAYS ON FOR APPROXIMATELY 5-7 SECONDS, THEN POWERS OFF. RED LED FLASHES 3 TIMES..PAUSES...THEN FLASHES AGAIN 3 SECS.
Posted on Feb 05, 2008
We have a Panasonic PT-56wx53 projection TV that has a double image problem. We have tried to fix the issue with the convergence feature, but the blue color will not line up, red and yellow working fine. ...
Does this problem happen all the time ? What I mean is , if your watching the local news thru your cable/sat box does ot happen, or just when using aux imput. Either way, double image, or shadowing, is usually caused by a defective wire. Troubleshoot each unit, unplug everything and start from scratch.
Mar 06, 2011 | Panasonic PT-56WX53 53" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Panasonic Rear Projection Screen TV
you need new convergence chips, there are 2, part number stk 392-110, also you must check for burnt resistors, if you don't have very good soldering skills at least, you will need a tv repairman.
Sep 15, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
The color looks off
most likely one of your component cables is loose or unplugged. this will stop one of the colors from coming through, thus throwning off your color. you need to check your red, blue, and green cables.
Jan 02, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Like the blue color is gone and see a double image now
You should have a TV repairman look at your set to see if you have a bad tube in the set, It might just be a convergence ishue, if thats the case it might be worth fixing.
Dec 15, 2008 | Panasonic PT-53WX42 53" Rear Projection...
53" Panasonic HDTV showing letters and shadow
maybe you have defective convergence correction circuit! replace a new one!
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
