Question about Dell Inspiron 9400 Notebook
Dell Inspiron 9400 PC Notebook replace hard drive
How do I replace a new 250gb hard drive on my Dell Inspiron 9400 PC Notebook ?
  • 1 more comment
  • luklik Mar 28, 2008
    I tried to add a Fujitsu 250gb HDD to my Dell Inspiron 9400 notebook, but the HDD was not visable.
    It couldn't be seen in the bios.
    The bios has also been upgrade & still didn't work.
    Contacted Dell 4 times before trying this & 2 technicians said these model notebooks can only support up to 100gb while the other 2 said it can be upraged to a maximum of 250gb, so I bought one & tried it.
    Any ideas ?
    Cheers!
  • theilluminat Sep 08, 2008
    How do I upgrade the hard drive on my dell e1705/inspiron 9400 laptop to over 100 gigabytes?
    Thank You,
    Mark
  • luklik May 11, 2010
    Hi EckD50
    Thanks for your reply which now confirms to me that it's possible to have more than 100gb installed.
    What is the latest Bios version available that can be used on these 9400's ?
    At the moment mine is A09.
    All the others I've seen on the website up to A13 are pointing at other model notebooks!
    Cheers.
  • 24 Answers
On the underneath side of the notebook there should be two screws that are usually labeled with a picture of a drum. Remove tham and the drive should slide out. Remove the drive from the tray you slid out and reverse procedure to re-install.
Posted on Jan 31, 2008
You should be able to upgrade no problems, i have a 320gb SATA drive in my 9400, runs fine...try getting the latest bios version.
Check that the connections are the same and you have moved any of the jumpers on the hard drive, see the manual or online help for the hard drive.
Posted on Jan 08, 2009
сtrdft
Posted on Oct 24, 2008
  • 43 Answers
Put your laptop up side down, so the front is turned toward you in right corner there is the HD bay. there is a screw holding it somewhere in that corner but I am not sure where exactly since I cannot get exact picture of the bottom
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Own a Dell Inspiron 9400 notebook in 2006. CD burner doesn't work - skips. Can I get an external CD/DVR RW?
In short, yes you can. A USB external drive will set you back about £30.00, however, if you look on ebay, you will probably get a replacement DVDRW for about half the cost
Mar 26, 2011 | Dell Inspiron 9400 Notebook
Inspiron 1721 can not find sata hard drive after post
Hi. You may need to reseat the hard drive by pulling it out and pushing it back in. If the system still won't boot to windows, and displays a " No Bootable Device Found" then you must have a busted hard drive. you may end up replacing the hard drive.
Hope it helps... ^_^
May 18, 2010 | Dell Inspiron 1721 17" Notebook PC, AMD...
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Cd jammed on top of cd drive of dell inspiron 9400 notebook
One screw on the bottom holding drive. Take it out, and pull drive.
Mar 27, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
Compatible CD/DVD Writer Models for the Dell Inspiron 9400
Replacements are UC823 and TS-L632 / TS-L632D , TS-L632D/DEKH.
If you had problem with TS-L632 you may need to update the bios.
Replacement here:
UC823 - DVD+RW 8X Optical Drive
Feb 08, 2009 | Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
How do I replace a DVD/CD Burner for Dell 9400 laptop?
No it is quite a simple change, but like anything electronic you should work carefully.
The drive is held in the laptop with a few small screws. Once you remove the screws...the drive slides out. In the space you can then slide in the BlueRay or HDDVD or whatever you wish to replace the present drive with.
Go for it the Dell...it looks like a nice machine!
Remember to rank me...please consider a FIX-YA...as anything else is actually negative...and hurts my rank..
.thanks
bearb
Nov 11, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
4,171 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
