Related Tags:
This problem should be removed because:
Problem with Sony BRAVIA KDL-40V2500 40 in. HDTV LCD Television
we have a sony kdl-32d3000 lcd tv.\r\non switch on
we have a sony kdl-32d3000 lcd tv. on switch on the screen displays coloured vertical stripes ?
after 3 mins they disappear & we can view tv picture, it does sometimes switch back to the stripes intermittently?
Solutions (1)
Lines in the Picture could be caused by Bad TCon or Sometimes Bad Main Signal Board.One indicator of the Bad TCon or Panel is if the lines are in menu also.
The panel is the whole front screen, The TCon is mounted on the panel ,the main board processes the signals and send the picture to the TCon then the panel.
Lines running top to bottom wider than an inch would indicate a bad TCon board.
According to Sony's website
Depending on your serial # the TCon board may or may not be available as a part.
Some only a complete panel is replaceable
serial range 6,000,001 - 6,280,000 = panel 1-802-699-12
serial 6,280,001 6,500,000 = panel 1-802-699-11
serial 6,600,001 and up panel 1-802-755-11 TCon 1-857-213-11
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
sony bravia kdl 32l4000 - color bars running...
sony bravia kdl 32l4000 - when you turn the tv on, there are color bars running vertically on the screen. they fade from light to dark but...
Bravia KDL-52XBR4, vertical stripe in center of...
Bravia KDL-52XBR4, has 4" wide speckled vertical stripe in center of screen. 15 months old.
My Sony KDL-32P3000 shows vertical stripes, and
My Sony KDL-32P3000 shows vertical stripes, and just stripes, nothing else, no picture.
intermittently dropping out from viewing (typ 30+
intermittently dropping out from viewing (typ 30+ mins) drops out to horizontal or vertical coloured lines. powering down and on again...
sony bravia kdl-40v2500 turn on for seconds off...
when i switched the tv on it comes on for seconds and went off and blink for 9 times and off
sony bravia lcd kdl-40v2500. come on for seconds...
i have checked power supply is ok i have changed the inverter board, still the sam on and off, i have checked the video...
Fix-O-Meter
1,250
1,250 people viewed this problem
- 0 people are following this problem. Be the first!
Top Sony Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Hey Taran,
I have a Sony KDL-32L4000 and i am having flickering that causes ghosting of lighter images on the screen. From what i have read i believe it is the TCON board because it will happen anywhere on the screen there is a light image. I was currious about your ealier post when you mentioned that a main identifier of a TCON board or panel is by if the flickering is in the Menu. My tv flickers all the time in any display but it is not specific to one area, just lighter images. Do you think it is the Tcon as well?
Thanks
